IP help
Old Apr 29, 2010 | 03:46 PM
mabc926's Avatar
mabc926
IP help
How do you remove the IP?
Went down to work on my truck today I was going to put the valley pan in but the IP was in the road.
I didn't want to mess up my timing or my IP so I just left it till I could ask you guy's.
Old Apr 29, 2010 | 08:13 PM
rupejosh's Avatar
rupejosh
i stole this from one of daves posts here is the link https://www.ford-trucks.com/forums/6...t-7-3-idi.html
On a NA engine, you should be able to remove the IP and all the injection lines as one unit.
Loosen all the nuts on the injection lines at the injectors.
Remove all three wire connectors from the IP.
Remove the throttle cable from the IP fuel lever.
Remove the supply line from the fuel filter to the IP.
Remove the return line from the IP.
Remove the throttle return spring.
Loosen the three nuts holding the IP to the IP drive gear cover.
Remove either the cover plate or the oil fill spout from the front of the IP drive gear cover.
Remove the three 5/16" 12 point bolts that hold the drive gear to the IP drive shaft.
Slide the IP straight back, finish removing the three nuts when you have enough room to turn them off.
Now slide the whole mess straight back while raising the rear of the IP.
It should lift right out.
Install, just start at the bottom of the list and go to the top.
Old Apr 29, 2010 | 08:33 PM
greywynd's Avatar
greywynd
Done this way, the ip drive gear will remain meshed, and therefore timed, correct?
Old Apr 29, 2010 | 08:36 PM
rupejosh's Avatar
rupejosh
90% sure yes.i havent pulled my ip yet so i cant be sure.but from what others say if you do it this way it wont affect timing
Old Apr 29, 2010 | 08:41 PM
mabc926's Avatar
mabc926
Alright..looks like I need to get me some 12 point sockets....as long as it stays timed that's all I'm worried about.
Thanks for the help man!
Also love Dave's part about the 1884 F250
deceptichop
Feb 27, 2011 07:52 AM
rodneywar
Oct 7, 2010 09:54 PM
bshep
Mar 18, 2009 03:40 PM
f100guy
Apr 15, 2007 01:22 PM
Andysutt
Aug 8, 2004 10:50 AM
