ScanGauge ll now installed
Old May 4, 2010 | 02:44 PM
  #31
william_04_x's Avatar
william_04_x
My EOT an ECT show equal and within a few degrees of ambient at cold start.
Old May 4, 2010 | 02:57 PM
  #32
hndacr's Avatar
hndacr
Do you think calling scangauge would get me anywhere?
Old May 4, 2010 | 05:24 PM
  #33
69cj's Avatar
69cj
Same with mine.
  #34
DoneDunIt's Avatar
DoneDunIt
My oil and water are the same after over night. Right at the outside air temp.
hndacr Make sure you only put the numbers and letters listed in the above notes. There is a Blank position that needs to be in place after the numbers. Do not leave any extra 0's in after what is listed.
Old May 4, 2010 | 05:26 PM
  #35
69cj's Avatar
69cj
Originally Posted by DoneDunIt
I found some info to get a Boost reading rather than the MAP. My ScanGaugeII reads 0.6 at idle and the Edge only shows whole numbers. Other reading are very close to reading on the Edge readings.
Boost Pressure
TXD: 68 6A F1 01 0B
RXF: 04 41 85 0B 00 00
RXD: 28 08
MTH: 00 91 00 64 FF 88
NAM: BST (or whatever that you prefer)
The last 4 values to the MTH above are specific for my altitude as I am located at around 5150 feet and it was a low pressure day. The MAP value can be used, but you will have to the math in your head to correct for barometric pressure. To correct for altitude, the blue highlighted value should be adjusted. Here are the corresponding values:
12.0 -- FF88 (mile high, low pressure day)
12.1 -- FF87
12.2 -- FF86 (mile high, high pressure day)
12.3 -- FF85
12.4 -- FF84
12.5 -- FF83
12.6 -- FF82
12.7 -- FF81
12.8 -- FF80
12.9 -- FF7F
13.0 -- FF7E
13.1 -- FF7D
13.2 -- FF7C
13.3 -- FF7B
13.4 -- FF7A
13.5 -- FF79
13.6 -- FF78
13.7 -- FF77
13.8 -- FF76
13.9 -- FF75
14.0 -- FF74
14.1 -- FF73
14.2 -- FF72
14.3 -- FF71
14.4 -- FF70
14.5 -- FF6F
14.6 -- FF6E
14.7 -- FF6D (sea level, 14.696 standard engineering day)
14.8 -- FF6C
14.9 -- FF6B
15.0 -- FF6A
These numbers don't work for me. Don't even get a read out.
Old May 4, 2010 | 06:56 PM
  #36
Spg01's Avatar
Spg01
I have the same problem with strange oil temps. This morning I read 70 for coolant and 112 for oil temp before I started my 05 6.0L. I called scangauge today and talked with Scott and he said there have been a few people with problems reading the EOT correctly. Currently I can read 193 for coolant and 260 for oil after highway driving.
I am taking it to the dealer thursday to have them check the temps while I watch. Since I just got it out of the shop and they said the temps were good.
Old May 6, 2010 | 05:15 PM
  #37
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
All right! Walked in the door and found my Scangauge II on the counter. I would like to get it in tonight, well, RIGHT NOW!, But will wait for morning when I'm a little more attentive. Will report tomorrow on programming.
Old May 6, 2010 | 05:23 PM
  #38
william_04_x
All you have to do is plug it in and you can read a whole bunch of stuff right out of the box. You can set your backlight color. You can find a good place to mount it. You really gonna let it sit there on the counter?
Old May 6, 2010 | 05:42 PM
  #39
amdriven2liv
It's been a 14 hour day, starting at 1:30 am this morning. Yep, it will sit till morning.....Unless the second margurita (sp) gets me up! Or third, after all it's my Friday!
Old May 6, 2010 | 05:48 PM
  #40
william_04_x
Just playin. 14hrs is a long day. Enjoy!!
Old May 6, 2010 | 06:09 PM
  #41
69cj's Avatar
69cj
I knew it had something to do with cocktail hour. LOL.
Old May 6, 2010 | 07:08 PM
  #42
amdriven2liv
third one poured, gettin the itch, wife just asked if it will clear my CEL!
Old May 7, 2010 | 01:52 PM
  #43
amdriven2liv
It's in. I have EOT, IPR, trannie, ICP, need to take it for a spin later to watch everything now. Tried Boost, but haven't got that one to work properly yet. Thanks to everyone's input! So far my oil and ECT are close, but that is just sitting in the drive.
Horse power didn't work on my 04.
Old May 7, 2010 | 02:22 PM
  #44
69cj's Avatar
69cj
I can't even get the boost to give a numerical read out of any kind.
Old Jun 14, 2010 | 02:57 PM
  #45
RedEagle58's Avatar
RedEagle58
ScanGauge ordered and should be here in a few days, thought it'd make a nice Father's Day gift to myself . Ordered direct from Linear Logic as I saved nearly $5 by not having to pay NC sales tax if ordered thru AutoZone.
'06 F250, 6.0, cc, Lariat, DieselSite coolant filter, high idle mod
