Sponsored by: Real Truck
Post your air compressor install pics
Old Apr 30, 2010 | 10:38 AM
Citypol86's Avatar
Citypol86
Low tech but let's people know you're there...
Twin short tanks siamesed, run by a single Hadley and horns are Hadleys from a Mack. Horns tuck nicely into the fender wells, are right up front and next to car-drivers' ears, don't add to possible leaks in the roof and angle down to assure they stay clear. Tanks and compressor fit in place of what I believe would be the second battery. All run by relays and switchable sans key. Total eBay cost- less than $150 and I still have 4 other horns hanging in my garage.
Later...
Brewster...
Old Apr 30, 2010 | 10:40 AM
rotun's Avatar
rotun
Reads ***** rules!
Originally Posted by 1975StroppeBaja
Nice air compressor setups.
Reps to all who have posted up pics. Well, except for Senix, gotta spread it around more first. Can somebody rep Senix for me?
This is something that would be awesome to install and setup but I don't have an immediate use for it. Its pretty low on my to-do list. Maybe someday I'll install some bags on the back and do it.
Rep sent to Senix!
Old Apr 30, 2010 | 11:38 AM
senix's Avatar
senix
Originally Posted by rotun
Rep sent to Senix!
Thanks for the reps! You all have given me some ideas on how to protect my compresser and tank.
One of things I encoutered was where to put my guage. I put it in the following pic. Seems to work pretty good there.
Old Apr 30, 2010 | 01:54 PM
HuntsDucks70's Avatar
HuntsDucks70
That's a nice setup. I'll eventually add a tank like that too. Right now I'm working on finding a place for the K5LA train horns.
Steve, here's the pics.
3rd battery (gel cell, deep cycle)
Junction blocks
Isolator
hidden switch
tank, again
plumbing to cab for inlet, amp feeds
inlet air filter (behind rear center console)
that is some luv right there! great work!
Old Apr 30, 2010 | 05:50 PM
rotun's Avatar
rotun
Reads ***** rules!
Thanks, looks like I need to do some vacuuming!
Old Apr 30, 2010 | 11:13 PM
JonathanN's Avatar
JonathanN
rotun,
What kinda PSI and CFM are you looking at? I've seen those old York pumps used as air compressors... I'm kinda looking for a setup that'll create enough air to run simple air tools. Tools like and impact wrench and maybe a ratchet or drill occasionally. Oh... and DEFINITELY to inflate flat tires!
Old May 1, 2010 | 04:07 AM
bkeeton's Avatar
bkeeton
My air compressor install .
SANY0018 on Flickr - Photo Sharing!
rig8 on Flickr - Photo Sharing!
Old May 1, 2010 | 08:04 AM
rotun's Avatar
rotun
Reads ***** rules!
Originally Posted by JonathanN
rotun,
Oh Yes...edc is the way to go if you have the room for it. Unfortunately I have the dual alternators so I have absolutely no room for one. Junk yards are a good place to find an edc, they put Yorks on the older Volvos and many people use those for air. As far as CFM the XD4000 has plenty. I have run die grinders, impact wrench and air ratchets off of mine and can do so without a tank. I have an IR regulator/ filter unit on it and can crank up the psi output from the tank to 160 and do when filling the 37's. Here's some tech. info on the 12 & the 24v XD4000's. For my 12v it is rated 8CFM@100psi. 100% duty cycle @200psi. I regulate to 90 when running tools. The more tank the better. The 100% duty cycle is alot of what sold me on it, as well as being an oil lubed/ non-sealed compressor it will definitely last my lifetime.
You should definitely have the room for an edc on your 7.3l. I have a ZENA stick welder, I'm in the process of mounting on my '03 7.3l after removing from my brothers '99 7.3.
Oasis Manufacturing - XD4000 Continuous-Duty Air Compressors - Compare Items
Old May 1, 2010 | 08:10 AM
Citypol86's Avatar
Citypol86
[have I got compressor envy...]
Old May 1, 2010 | 08:30 AM
rotun's Avatar
rotun
Reads ***** rules!
Originally Posted by bkeeton
Come on now! That's cheating. Good first post though, now I'm going to have to post my work trucks as well.
Old May 1, 2010 | 08:48 AM
JonathanN's Avatar
JonathanN
rotun,
That's what I was looking for... I was actually looking to run something similar to yours. I really didn't want to have to try to mount it on the engine... unless any of you could give me a good reason why I should. But yeah, that's a nice setup. I can't wait to do mine!
Old May 1, 2010 | 04:24 PM
bkeeton's Avatar
bkeeton
Hehe , thanks ! Yeah , post up some pics !
Old May 3, 2010 | 09:58 PM
  #28
SD-Dude's Avatar
SD-Dude
has anyone ever seen and setups behind the seats ? just wondering if i could get something behind my rear bench seat. how do all your setups handle the winters and road salt ?
Old May 6, 2010 | 05:02 PM
  #29
rotun's Avatar
rotun
Reads ***** rules!
Well, here are 2 of my trucks that have compressors behind the seats..................they are a little loud though!
<a href="http://s491.photobucket.com/albums/rr272/RotunTuna/?action=view&current=SHOPSTUFF002E.jpg" target="_blank"><img src="http://i491.photobucket.com/albums/rr272/RotunTuna/SHOPSTUFF002E.jpg" border="0" alt="Photobucket"></a>
<a href="http://s491.photobucket.com/albums/rr272/RotunTuna/?action=view&current=SHOPSTUFF001E.jpg" target="_blank"><img src="http://i491.photobucket.com/albums/rr272/RotunTuna/SHOPSTUFF001E.jpg" border="0" alt="Photobucket"></a>
Old May 6, 2010 | 09:19 PM
  #30
JonathanN's Avatar
JonathanN
Ok, here's what I've got in mind: I know that some AC setups have two compressors instead of one. How about taking two york compressors and hooking them up to a motor with two output shafts, one on either end? Would this work? The only thing I can think of that wouldn't make it work is the fact that one would spin the "right" way and the other would spin the "wrong" way. What are y'all's thoughts? I want a really robust setup that would be able to keep up with ALMOST anything I could throw at it.
