Boost
Old Apr 28, 2010 | 10:24 PM
460/5's Avatar
460/5
Zombie Survivalist
Boost
hey yall. im kinda tossin round the idea of gettin a 70 f250 with a 300 in it. ive also got a friend with three 25 millimeter turbos (two work fine, the third needs rebuilt) that hes willin to sell to me for $200. i, bein the mad scientist i am, want better fuel economy and more power, and am thinkin to put all three on the 300. itd be a two into one setup, and i estimate 30 to 40 lbs of boost, through a four barrel TBI injection. my question is: will a bone stock 300 be able to handle that kind of pressure?? and would i even be able to run standard 87 pump gas at that rate?
Old Apr 29, 2010 | 09:26 AM
AbandonedBronco's Avatar
AbandonedBronco
Check out this forum:
FORDSIX PERFORMANCE • View forum - Turbo, Supercharger, and Nitrous
Either way, if you're serious about the project and complete it, POST PICS! I'd love to see that.
Old Apr 29, 2010 | 10:31 AM
460/5's Avatar
460/5
Zombie Survivalist
if it goes through for me, i will for sure!
Old Apr 29, 2010 | 12:15 PM
Harte3's Avatar
Harte3
IIRC, anything more than about 5lbs.of boost and it's demolition time. 30-40 lbs.of boost is in the big truck (18 wheeler) range.
Old Apr 29, 2010 | 12:20 PM
AbandonedBronco
True. And if I remember the formula right, 5 lbs is plenty for the 300 as is.
Low end = (0.053 * ci * (boost + 14.7))
High end = (0.077 * ci * (boost + 14.7))
So 5lbs is 313 to 455 hp, which is still a whole lot. 40 lbs would be 870 to 1264hp. Not sure many engines at all can take that kinda cranking on stock internals.
Old Apr 29, 2010 | 12:28 PM
fatdan460's Avatar
fatdan460
and so trey's pipe dream dies
Old Apr 29, 2010 | 12:37 PM
Harte3's Avatar
Harte3
Better the dream die than the engine grenade...but man going to the moon was a dream at one time too.
Old Apr 30, 2010 | 12:08 AM
460/5's Avatar
460/5
Zombie Survivalist
i know its a lot of boost. but bein american iron i figured it should be able to handle fairly decent boost levels at least (i.e. 20 lbs), seeins as the guy id be gettin em from runs 20+ in his stock saab motor...
Old Apr 30, 2010 | 12:27 AM
fatdan460's Avatar
fatdan460
but saabs are built from jets you would probably have to go with arp head studs at the least, and this is all i can suggest, because other than my dad's harley having a turbo on it, i have no experience with them first hand
Old Apr 30, 2010 | 12:31 AM
460/5's Avatar
460/5
Zombie Survivalist
i was wonderin if i might need some ARPs... i wonder how well a stock 4.0 would receive boost...?
Old Apr 30, 2010 | 12:39 AM
fatdan460's Avatar
fatdan460
probably about the same. if a motor wasn't meant for a turbo, there is a lot of stuff that will need to be changed, and don't forget about compression ratio
Old Apr 30, 2010 | 12:40 AM
460/5's Avatar
460/5
Zombie Survivalist
well the good thing is that the compression ratios of the older motors like that wasnt too extreme...
Old Apr 30, 2010 | 12:47 AM
fatdan460's Avatar
fatdan460
but the stock pistons will be the first thing to say "trey why did you do this to me?"
Old Apr 30, 2010 | 12:55 AM
460/5's Avatar
460/5
Zombie Survivalist
lol. and then ill have an excuse to make the old horse a stroker and throw a cam in the mix, and beef things up to handle 30+ psi...
Old Apr 30, 2010 | 01:17 AM
fatdan460's Avatar
fatdan460
well, i guess all i can say is do it. and when it blows, and it will, post pics and vids
