non start question
Old Apr 28, 2010 | 10:12 PM
galaxie521's Avatar
galaxie521
non start question
3 weeks ago i bought a 2002 f350 with a 7.3. two different times after a short drive when i try to start it the starter turns over fine but it will not fire. the first time i let it set for 45 minutes and it started fine. the next time i tried it after about 5 minutes and it started any help would be great. this is my first diesel so i am lost. thanks Todd
<!-- / message -->
<!-- controls -->
Old Apr 29, 2010 | 04:18 AM
ron's power stroke's Avatar
ron's power stroke
clean all battery post really good..load test both batts while they are un hooked...these thing will crank all day long like the batts are strong..but if you dont have at laest 10.5 when cranking..she will never fire...
Old Apr 29, 2010 | 06:41 AM
riverrat41's Avatar
riverrat41
If Ron is right and the batts are the problem.Change both of them,not just one.
Old Apr 29, 2010 | 09:23 AM
galaxie521's Avatar
galaxie521
thanks i will start with them
Old May 31, 2010 | 11:08 PM
galaxie521's Avatar
galaxie521
well i cleaned all the posts and some other connections that were crusty looking.then had the batteries tested an was told they were fine. under a heavy draw down test one was 9.4 and the other was 9.5.the truck has been fine for a month. then today no start after a short trip.then 10 minutes later it was fine is 9.4 and 9.5 on a draw down too low? thanks Todd
Old May 31, 2010 | 11:29 PM
Visseroth's Avatar
Visseroth
You need to test them while they are tied together. You can NOT drop below 10.5 on start or the IDM will not have enough voltage or current to generate the 1.1 Gigawatts.... Oh oops, to much Back to the Future, I mean 110v to 140v to fire the injectors and let fuel into the cylinders to start the engine.
frdf250
Projects
Jan 8, 2012 08:19 PM
Bigpapa346
3.0L V6
Oct 15, 2011 01:04 PM
maxtruck00
Dec 19, 2010 06:24 AM
dirtmod66
Nov 20, 2010 05:01 PM
