Hey, why don't we start filling tires with Helium. It should incrementally reduce the weight of the truck and increase gas mileage. Sounds like a job for the Mythbusters!
Nitrogen will not expand under every day driving conditions! That's the whole point behind nitrogen in tires!
Originally Posted by F250nube
Yes, but what's the point? The reason for nitrogen is that it's inert. Meaning that with increasing temperature it won't change, or more importantly expand. With temperature air expands. Mixing air and nitrogen defeats the whole point of nitrogen in the first place.
As was stated by gearloose1 both of these statements are false.
Nitrogen gas may be inert, but this has nothing to do with isentropic expansion. The expansion of nitrogen in your tires can be modeled the same as air using the ideal gas law, since at the temperatures and pressures in your tires, both air and straight nitrogen behave as an ideal gas.
PV=nRT
ALSO, just FYI, I just did a quick calculation and it seams that if you place a tire on a rim and then fill the tire with 100% N2 to 50 psig you will have about 95-96% N2 and 4-5% other gasses from the air that was in the tire before you added the nitrogen.
Not only that, but while you're topping off you can make your voice sound funny!
We used helium (like up to 200 psi) on some of our human powered vehicles during top speed runs.
Had to re-fill every run. Reason: Helium molecules are so small they pass through rubber.
That was the original reason for using nitrogen in tires, to reduce rate of leakage.
But it is 99% marketing. And some would say bad marketing, as it causes many not-so-educated folks to think they never have to check tire pressures. As use becomes more common, I bet we keep seeing more tire failures/blowouts/rollovers.
Touche!
That is, unless you filled the tire / rim in a chamber that is purged with nitrogen!
The real benefit of filling with Nitrogen is that it is relatively inert.
Heat it up enough, and it is reactive, but much less so than Oxygen.
Furthermore, since N2 is normally purchased from a gas vendor, it is likely to contain very little moisture vs. normal compressed air, which is often filled to the saturation capacity of compressed air at its current pressure --- that is why all compressed air tanks have a water drain.
If you were to fill with dry air, much of the benefits of a Nitrogen fill are captured.
True, there is a small benefit in having a relatively more inert gas, but that is minor --- Oxygen will diffuse into the rubber from the outside, especially the tire damaging / rotting O3. (Ozone).
The bottom line --- if it came filled with nitrogen for free, sure!
But don't sweat too much or spend much trying to maintain it by only filling with Nitrogen.
A regular service station fill.... according to wise guy calculation above.. leaves 4-5% O2 in the tire unless the tire / rim were filled in a Nitrogen gas purged enclosure.
So a nitrogen fill goes from 78% nitrogen with regular air to maybe 95%.
Do an estimate of the weight of the helium gas compressed (remember you have to overfill it a bit because of the rapid leak down)....
vs.
The weight of ordinary air.
Then see if there is any difference in displacement.
Ask yourself if you can make as much of a difference visiting the John before going off on your ride....
Actually, when a tire heats up under severe stresses, the oxygen in the air inside the tire can more readily react with the rubber, causing it to become harder and more brittle over time. Under normal wear and tear, this can weaken the overall structure of the tire. This may seem insignificant, but how many blowouts occur in theis country, both from underinflated tires (air leaks out, nitrogen is less prone to this) and due to the rubber breaking down and failing? I think its a hard case to settle, but before arguing that regular air is fine, I think we should consider that there are problems that occur with normal air. I'm not sure how much longer a tire can hold up with nitrogen filled tire, but I do know that for vehicles that are driven infrequently, so that the tires get old but do not see a lot of use, nitrogen has some very strong advantages. It can keep the rubber supple longer and decrease the chances that the tire will be flat when you go to use the vehicle. For everyday use, harder call.
All this talk about Oxygen vs. Nitrogen and not one of you has mentioned how often you need to change the air (or nitrogen) in tires!
I know some say every 3,000 miles is "cheap insurance" while others say the manufacturers recommended interval of 7,500 miles is fine considering the tighter manufacturing tolerances of modern tires and wheels. Then of course you have the die-hard fans of synthetic air who say they only have to change the air in their tires every 15,000 miles (talk about drinking the Kool-aid).
Don't even get me started on whether an oiled cotton (K&N style) air filter is better than a paper air filter when it comes to actually inflating the tires!!!
