Clutch
Old Apr 28, 2010 | 04:36 PM
salf100's Avatar
salf100
Clutch
So I bought a new 10" clutch for DC and it doesnt fit
Its too small. Anyone know how I can figure out the correct clutch size? I see that DC offers a 10 and 11" version. My truck is a 64 F100 w/292 and 3spd 3.03 tranny on the column.
I measured the presure plate and the disc and they are both 10 1/2". I can only find the 10 and 11" clutches. I also checked an original Ford shop manual and it states the disc is 10 1/2" in diameter ???? I'm clueless.
Did some checking around and was told that Ford used a 10 1/2" clutch ONLY on the 64 model ????? ND please help.
Old Apr 29, 2010 | 07:22 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by salf100
So I bought a new 10" clutch for DC and it doesnt fit. It's too small.
Because, it's for a 1962/64 F100 I-6.
I also checked an original Ford shop manual and it states the disc is 10 1/2" in diameter.
Did some checking around and was told that Ford used a 10 1/2" clutch ONLY on the 64 model?
Whoever told you that doesn't know diddly-squat!
Two different sized clutches were offered for 1956/64 F100 Y blocks: 10 1/2" and 11"
But there's only one flywheel, which has a 12 3/8" bolt circle the pressure plate bolts to.
This means you can use either the 10 1/2" or 11" clutch.
C3TZ7550G (replaced B7C7550B) .. 10 1/2" Clutch Disc / Obsolete
GRIESEL MOTOR CO, in Okarche OK has 1 = 405-263-7242.
GREEN SALES CO. in Cincinnati OH has 16 = 800-543-4959.
B6C7563A .. 10 1/2" Pressure Plate / Obsolete
GRIESEL MOTOR CO. has 1.
GREEN SALES has 3.
I'd be willing to bet that Griesel will be a heck of a lot cheaper than Green Sales.
Old Apr 29, 2010 | 12:56 PM
salf100's Avatar
salf100
Well, Giesels was all out, but Green Sales had it. Odered! Hopfully no more hitches on this one.
Thanks ND.
mutant
Jun 12, 2014 08:07 PM
64fordf100292
Sep 3, 2009 03:29 PM
sissini
Feb 25, 2008 07:58 PM
highboy 74
Jan 3, 2006 12:58 AM
blu_ford_100
13
May 25, 2004 11:31 PM
