Engine Codes P0299 & P0478
Old Apr 28, 2010 | 03:43 PM
jdt-scursion's Avatar
jdt-scursion
Hey All-my check engine light came on......pulled the following codes: P0299 Turbo Under Boost
P0478 Exhaust Pressure Control Valve High Input
I have 05 Excursion w/Edge-Juice programmer, AEM intake and Banks exhaust....other than that it's bone stock. Any insight & guidance would be appreciated!!!
Old Apr 28, 2010 | 04:26 PM
KRDiesel's Avatar
KRDiesel
First thing I would do is remove the Edge, check your CAC hoses for leaks, clear the codes and see if it comes back.
Old Apr 28, 2010 | 04:33 PM
jdt-scursion
KRDiesel-not sure what CAC hoses are?? sorry newbie to diesel talk....
Old Apr 28, 2010 | 04:37 PM
jdt-scursion
the silicon hose the connects the turbo to intercooler had a split, just ordered replacements for both ends (dielselsite)......i'll keep you posted, hope this clears up the issue...
Thanks for the guidance!!!! much appreciated
Old Apr 28, 2010 | 04:40 PM
KRDiesel's Avatar
KRDiesel
That is a common place for them to split, It should clear up your issue.
Old Apr 28, 2010 | 06:47 PM
cheezit's Avatar
cheezit
the po478 can set the p0299. check ebp map and baro psi pids koeo value they should all be about 14.2-14.7 psi.
Old Apr 28, 2010 | 06:58 PM
69cj's Avatar
69cj
Side note; the Edge juice has not been noted for being very good for the Torque-shift tranny.
Old Apr 28, 2010 | 07:31 PM
03-6L-X's Avatar
03-6L-X
Make sure you clean everything with brake cleaner to get rid of any oil film. Then take some hair spray and spray a "light mist" on the tube and the hose before you put them back together. Should keep you from having the or a big bang under the hood as you step on it getting on the freeway or going up a hill.
Old Apr 28, 2010 | 08:02 PM
gearloose1's Avatar
gearloose1
You have the situation under control.
In my case, the issue was a badly plugged EGR.
MelissaBurney
6.7L Power Stroke Diesel
Jun 2, 2017 07:00 AM
VRC9170
Nov 7, 2015 10:04 PM
awillo0406
20
May 7, 2013 02:58 PM
speedbanger90
Jan 21, 2012 04:01 PM
Viper1837
Jul 12, 2007 05:46 PM
