1994 F250 headlight dim and dash turn signal indicator light on ?
When I turn on the the headlights on my 1994 F250 IDI , the (green) right turn signal on the instrument panel is lit (dim) and the right headlight works but is somewhat dim . The turn signals apprear to be working normally and rt indicator blinks when ts is active . . Is this a common problem ?. Where do I start in troubleshooting / fixing this situation . - Thanks
I cleaned the headlight connections and the ground wire terminal connections under the hood the near front of the upper right fender (2 black wires with round terminals connected to stud with a 7/16 " nut and washer ). This took care of both problems. The right headllamp is operating properly and the green indicator light is off .
dmarsh2400
08-19-2019 03:23 PM
bobs 80 f250
16
07-10-2015 01:59 PM
