Truck stalling while under power.
Old Apr 27, 2010 | 10:06 PM
Scrambler81's Avatar
Scrambler81
While driveing to work one morning I shifted into 3rd gear let the clutch out gave it gas like normal when suddenly the engine cut out for a second the truck slowed down then kicked back on and took off, it drove normal for a while then it did it again. On the way home it happened again but didn't recover so I shifted out of 3rd and into 4th then it recovered drove fine the rest of the way home. I tried driveing it yesterday now I can't shift out of 1st before it just stalls out. if it helps any my truck is a 95 f150 5.0l with efi, 5 speed, 4x4. The transmission is a reman with maybe 300 miles on it so I know it's not a transmission issue. Any help would be much appreciated.
Old Apr 29, 2010 | 07:32 PM
Scrambler81
I see a few people have viewed this thread but no one has responded to it, if I can help you understand what my problem is let me know and I'll try to answer your question the best I can.
Old Apr 29, 2010 | 10:56 PM
rla2005's Avatar
rla2005
Fuel or spark come to mind. Pull a plug and check the spark. For that matter how old are the ignition pieces? Same for the fuel filter? What other work has been done to it recently? Any Check Engine Light? Check for codes. Many times there can be stored error codes without turning on the CEL.
Old Apr 29, 2010 | 11:15 PM
Filmy's Avatar
Filmy
+1 on the fuel filter. The fuel seems to flow okay at low RPMs but if a lot of gas is needed all at once, that flow gets clogged. Either the filter or you have a load of crap in the tank, clogging the "sock" under pressure.
Old Apr 30, 2010 | 12:02 AM
66crew's Avatar
66crew
Sounds like a bad fuel pump
Old Apr 30, 2010 | 06:37 AM
DBGrif91's Avatar
DBGrif91
I had a similar issue on my 91 F150. It turned out to be the TPS. Is it doing this all the time or just when it's hot? Mine only acted up after the engine was up to temp.
Old Apr 30, 2010 | 05:02 PM
Scrambler81
The fuel filter, starter, spark plugs, distributor cap, ide air control value, rotor button, new ram proformance clutch, flywheel, pilot bearing, slave clyinder, battery, K&N air filter, locked rear dif, 31" tires are all new plus a remaned zf s542 transmission. the rest of the truck is original factory parts. The check engine light comes on every now and then. If it helps any I had the truck idleing in the drive way for 15 mins and it ran just fine until i tried to drive it.
Old Apr 30, 2010 | 05:05 PM
Conanski's Avatar
Conanski
Check fuel pressure and pull the codes.
Old Apr 30, 2010 | 05:09 PM
Scrambler81
I guess all the time seems to happen more when it's hot. Had to have the TPS replaced a month or so after I got the truck.
Old Apr 30, 2010 | 05:11 PM
Conanski's Avatar
Conanski
It could be a failing TFI module then.. the codes will confirm.
Old Apr 30, 2010 | 06:12 PM
Scrambler81
I have EFI. Are TFI and EFI the same thing or are they different systems?
Old Apr 30, 2010 | 08:24 PM
ymeski56's Avatar
ymeski56
Der Postmeister
You have both. Electronic Fuel injection (EFI) & a Thick Film Ignition (TFI) System. For a 95' it (the TFI Module) should be mounted on the driverside fenderwell & will be black. Here's a diagram on this link. Ford Fuel Injection Setting the timing
Old May 1, 2010 | 05:50 AM
Scrambler81
Thanks I'll look into replaceing the TFI module and check the fuel pressure.
Old May 1, 2010 | 09:01 AM
ymeski56's Avatar
ymeski56
Der Postmeister
Do Error code scans before replacing anything. One of these, Equus Innova 3145 OBD-I Ford Scan Tool or it can also be done manually Ford Fuel Injection How To Run a Self-Test
As it could also be your PIP sensor (stator)
Ford Fuel Injection Stator (RPM)
You can also take your TFI module in to have bench checked, & as Cski also mentioned, you need to rule out fuel by testing for too.
Old May 1, 2010 | 09:32 AM
rla2005's Avatar
rla2005
If there are no codes my bet is on the PIP.
