Txfire76, do your switches light up in the off position when you turn your dash illumination on?
Yes they do. The AUX tags on the switches are controlled by the factory backlighting and then there is a small led on the tip of the switch that lights up when the switch is activated. Hope that helps.
I'll post a pic later. I just got done wiring them up, Plugs in to factory fuse box with moving only 2 wires around
Say...if anyone is looking for a upfitter switch panel...mine is for sale in the classified section. I decided 4 wasn't enough so I had to make some changes....
Love the panel and looks great...just wasn't functional for me.....
