Upfitter info needed
Old May 8, 2010 | 05:53 PM
Waltdog's Avatar
Waltdog
of American machinists
I recently found the OEM upfitter kit I bought back in 05 when they came out. I never got around to mounting it up, Theres some archived info in the tech folder,but not the thread I need. Any links of info would be great.
Old May 8, 2010 | 08:24 PM
Waltdog's Avatar
Waltdog
I am sure this info is old hat to some but here is what I have found so far:
Installing Upfitter Switches - Ford 2005-2007 Superduty
Obviously this is for a 6 leaker, It does however show the proper place to mount the relay box.
ETA : PDF from Fleetford
https://www.fleet.ford.com/truckbbas/non-html/Q117.pdf
ETA AGAIN! Found Ryan's (Strokersace) Post I was looking for:
https://www.ford-trucks.com/forums/7...ml#post5885336
Old May 9, 2010 | 08:04 PM
Waltdog's Avatar
Waltdog
Bump! I mounted the relay box today and ran the harness. The links I posted cover the majority of the info. If anyone has any first hand knowledge of making upfitters work in a pre 2005 truck post it up.
Old May 23, 2010 | 10:12 PM
Waltdog's Avatar
Waltdog
Wrapped up this install today. OEM Upfitters and OEM 05 Lower dash W/ Driver glove box.
Old May 23, 2010 | 10:44 PM
jeff7825's Avatar
jeff7825
Looks good. The color matches really good on your truck it seems. I did this mod on my old 01 F-250, but I couldn't get the color to match good enough for my taste, so I took it out and never re-installed it.
Old May 23, 2010 | 10:58 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Looks good.
Old Sep 24, 2010 | 09:03 PM
elee3's Avatar
elee3
Great job Waltdog. I have the same interior as you and would love to do this mod. About how much were the parts?
BTW, is that a wire EDM in your avatar?
Old Sep 24, 2010 | 11:23 PM
Waynenap's Avatar
Waynenap
Looks real good!
On an off note; What kind of floor mats do you have? They are plain looking and look real adequate.
Old Sep 24, 2010 | 11:29 PM
Waltdog's Avatar
Waltdog
I bought the upfitter kit back in 05 when they came out for about 58 bucks, they are close to 100 now for the upfitters.
The other four pieces cost 191 from Ed.
$249 then, Plus a bit of time doing the wiring/fiting of the components.
Wire EDM!! Yep EDM machinist here, I run the EDM department at small tool/die shop.
I use the #1 switch every day in the AM to turn some aux lights on.
Originally Posted by Waynenap
Looks real good!
In those pictures all floor mats are removed,that is the OEM XLT carpet
Old Sep 24, 2010 | 11:39 PM
Waynenap's Avatar
Waynenap
Sorry to be a nuisance. It looked like a rubber mat.
Old Sep 8, 2012 | 01:12 PM
Sunnshhinecrime's Avatar
Sunnshhinecrime
Where did you get the lower dash with the glove box? I saw this thread and want to do it to my 2000 f350 now. Also what is the thing with the hook on the bottom right corner of the lower dash?
Old Sep 8, 2012 | 02:18 PM
Bonanza35's Avatar
Bonanza35
Thats where your ash tray goes. I to like the glove box.
Chet
Old Sep 8, 2012 | 10:12 PM
carltonwebb's Avatar
carltonwebb
The glove box lower dash is from a 2005+ year truck. Up to 2007. I think clay maybe had them at at one time. If not, you can order them from any ford dealer or junkyard of your choice. I had a 2007 once and used the little glove box to put my wallet in on long trips to keep my back from hurting.
I really could not tell you what the little hook thing is for other than to hang a trash bag.
Old Apr 21, 2013 | 08:44 AM
gramicko's Avatar
gramicko
To install 05' lower dash panel, did you have to trim anything? thanks
Old Apr 3, 2014 | 06:13 AM
Road Hog's Avatar
Road Hog
Is there a wire diagram for installing Upfitter switches in Ford F250 2004 ?
