Ford vs Nitro
Old Apr 27, 2010 | 01:48 PM
skyfox10's Avatar
skyfox10
Ford vs Nitro
I've been ready to buy my gears for awhile, but I'm not sure what to do about getting an LS as well. should I look for an OEM LS or is there a preferred brand out there?
I've been looking at a Nitro Power Lock. Are these decent differentials? I know the fords can be built to actually function decently, but what is going to give the best results for a truck that is driven 90% on road?
Old Apr 27, 2010 | 03:13 PM
94MustangGT's Avatar
94MustangGT
Never heard of the Nitro.
I would go with the Ford T-Lok anyways... Should be the best on/offroad performer for the dollar. Also, if you use it on snow covered roads, the T-Lok works well because it is not too tight.
I have OEM Ford T-Loks in both the car and the truck. Both are still working well after 145K+ miles each.
Old Apr 27, 2010 | 03:31 PM
Old Hickory's Avatar
Old Hickory
Take a look at an Auburn Pro LS. I love the one in my truck. Summit and Jegs sell them.
Old Apr 27, 2010 | 04:43 PM
lew52's Avatar
lew52
I like the detroit , eaton truetrac , there hard to beat , there a little expensive , but you get what you pay for....Lew
Old Apr 27, 2010 | 09:56 PM
skyfox10's Avatar
skyfox10
here is the web page.
Positractions - Nitro Gear & Axle.
I'm not to worried about the price, as long as the guy I'm buying them from can get them. I've got a deal set up where I can barter for the parts I want.
EDIT: Also, this is probably where the gears would be coming from. According to this 4x4 shop. All gears you get now come from the same factory in Korea.
Old Apr 27, 2010 | 10:12 PM
94MustangGT
^ The Nitro doesn't list a unit for our 8.8 axles, unless I'm missing something...
Old Apr 27, 2010 | 10:20 PM
skyfox10's Avatar
skyfox10
Very good point. I assume the ford 8 is different than the 8.8. Is this correct? Because maybe he was refering to the trac lock and misspoke. But that seems like a very big oversight on the manufacturer's part to call an 8.8 an 8.
Old Apr 28, 2010 | 04:44 AM
Old Hickory
A Ford 8 inch rear end is indeed different from an 8.8. It was used in smaller cars in the
1960s and 70s and is a removable carrier type like the 9 inch is. Thousands of Mustangs,
Falcons, Fairlanes, etc used the 8 inch.
Old Apr 28, 2010 | 05:36 AM
TexasGuy001's Avatar
TexasGuy001
I recommend the Ford traction lock. Its inexpensive, operates smoothly and is rebuildable. I have also had the Auburn LS and I must say that I did like it alot too, but I don't think it is rebuildable.
Old Apr 28, 2010 | 08:03 AM
skyfox10's Avatar
skyfox10
looks like I'm gonna have to tear into my parts truck again. Maybe I can find some time this weekend.
Old Apr 29, 2010 | 04:09 AM
TexasGuy001
Does your parts truck have LS? That would be cool if it did.
Old Apr 29, 2010 | 08:46 AM
skyfox10's Avatar
skyfox10
parts truck has factory 3.55 LS in front & rear. I still haven't decided if I should put LS in the front too.
Old Apr 29, 2010 | 09:50 AM
6CylBill's Avatar
6CylBill
Personally, I would LS both the front and the rear. But just a normal Ford LS for the front.
Old Apr 29, 2010 | 09:15 PM
94MustangGT
I have heard that factory front and rear LS's was an option, but have never seen one before....
What's the axle code?
Old Apr 29, 2010 | 11:43 PM
skyfox10's Avatar
skyfox10
It's an H9B
