Engine Ticking 5.4L 2003 Expy
Old Apr 27, 2010 | 12:31 PM
erniek70's Avatar
erniek70
Does anyone ahve more detail on TSB 16403? Reason I ask, I truck has recently developed a ticking noise (80000 miles). Usually on cold start-up. Sounds like in the valve train. However, I have noticed that the dealer, on their last service, put in too much oil (roughly 1/2" over max). COUld this have casued any issues, or created the ticking noise. It does go away after a while...but the noise is rather embarassing.
TSB 16403...that is the United States TSB number. Does anyone know the Canadian TSB number? They're different (usually 6 digits).
Old Apr 27, 2010 | 06:44 PM
Big Greenie's Avatar
Big Greenie
Temporarily Deactivated
The 5.4 is notorious for being noisy on cold starts. Most of the time it is a little piston slap, sometimes mine makes a little valvetrain rattle too.
Slightly overfilling the crankcase did not cause the problem. It is simply age. There is also nothing to worry about. If it is quiet when warmed up a little, what you hear is normal for the 5.4, and I wouldn't worry about it. keep doing regular maint and the engine will go 300k miles easy.
Old Apr 27, 2010 | 08:35 PM
alloro's Avatar
alloro
Look through each of the front wheel wells at the exhaust manifolds. Count the number of nuts/studs that you see on each of them. Anything less than 8 on either of the manifolds and you've found the source of the ticking noise.
Old Apr 29, 2010 | 11:54 AM
erniek70's Avatar
erniek70
tough to see the studs! how on earth do I look at them? too much stuff in the way!
Old Apr 29, 2010 | 02:58 PM
TexFinn's Avatar
TexFinn
My wife's 04 Expedition also has an intermittent piston slap issue on cold starts. Sometimes it actually get pretty loud, but goes away after a few seconds. Luckily.
Nothing too much to worry about.
It is pretty tough to see there, for sure, but what you could also do is to stick your hand in there and try feeling them. Better do that while the engine is cold, though...
Old Apr 29, 2010 | 03:00 PM
erniek70's Avatar
erniek70
Do you know nut head size? I could probably feel my way around with a wrench/socket. I guess I can find out on the 3rd bank....I can see those nits. They aren't very big! no wonder they break
Old Apr 29, 2010 | 04:21 PM
alloro's Avatar
alloro
You can jack up the front end and let the tires hang which will give you more room. You can also take the tires off or remove the wheel well skirts if you need to. You can also try looking down from the top and use a bright light and a mirror.
coolidge54
Mar 8, 2019 12:03 PM
47 flatbed
2009 - 2014 F150
21
May 1, 2017 09:59 AM
BowTieHatr
6.4L Power Stroke Diesel
Oct 19, 2012 08:40 PM
Sheryle
Dec 21, 2011 04:01 PM
Chaosracing
May 6, 2009 10:58 PM
