loud tapping
Old Apr 26, 2010 | 10:21 AM
714x4custom's Avatar
714x4custom
loud tapping
Hey guys,
I have a newly rebult 390, with about 400 miles on it, When you start the truck there is no noice but when it gets warm, a tapping noice starts! Any ideas what this could be? I do have a header leak but this is not that! Sometimes it wont even make it, but most of the time when engine is warm it will make the noice?
my only toughts are pushrods to long, or stuck lifter, But I am unsure what both of those would sound like?
Still runs fine...
Thanks
Old Apr 26, 2010 | 01:35 PM
Bear 45/70's Avatar
Bear 45/70
Originally Posted by 714x4custom
Hey guys,
Still runs fine...
Thanks
Or a lifter going flat (not staying pumped up) part of the time. A too long push rod would probably cause a flat or weak cylinder rather than be noisy.
Old Apr 27, 2010 | 10:23 PM
714x4custom
yea, here is a video so you can hear what im talking about!
its only when the trucks warms up and the warmer it gets the louder!
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf?file=http://vid244.photobucket.com/albums/gg16/sexyspeer/MVI_1295.flv">
Old May 1, 2010 | 02:31 AM
Amtek's Avatar
Amtek
Definitely sounds like something in the top end (cam/lifter/pushrod/rocker/valve) because the sound repeats slower than the engine RPM. Time to pop the valve covers.
Old May 1, 2010 | 04:36 PM
LT.'s Avatar
LT.
Agreed. You have something in the top end making the noise. If you get yourself a stick and place it on different places on the valve cover you can narrow your search down. Use it like a poor mans stethoscope. This will at least get you to the right cylinder. Good luck.
LT.
Old Jul 2, 2010 | 03:40 AM
durtbahl's Avatar
durtbahl
expedition failure
Ticking valves progressed to a noticably...something's getting ready to happen sound, so I pulled over. In doing so she lost all oil pressure. So... by the time(<60 seconds) I rolled to a stop, truck stopped running and upon attempted restart, observation said she had a seizure.
2.5 hours prior I was gifted from my fiance this truck (1999 expedition 5.4L)
125000 miles old.
'Fis was you, what'd you think I should do? ((feed me some good beta/advice)(Tell me what to did or at least whatchyodeww if this was you)).
Might seem easy stoopid for problem solved, I won't take offense to what seems obvious to advisor(you)I'm asking for ideas please.
Apreciated are your replies..., signed, Durtbahl
Old Jul 2, 2010 | 09:35 AM
sturzinator's Avatar
sturzinator
That's what my engine sounded like. Pop the valve cover and see which lifter isn't moving the full stroke. Mine ended up being a rounded off lifter and cam lobe.
See this thread for pics/explanation of failure:
https://www.ford-trucks.com/forums/9...is-before.html
Old Jul 2, 2010 | 05:33 PM
714x4custom
Thanks man, I will start ripping it apart to look!
Old Jul 2, 2010 | 05:36 PM
714x4custom
great help FTE
Old Jul 5, 2010 | 04:44 PM
714x4custom
So how do you check to see if the lifter if making its full stroke?
Old Jul 6, 2010 | 09:30 AM
sturzinator
Pop the valve covers off. Start up the engine and watch the rocker movement. With the noise that your engine is making, I would think it would be pretty obvious which one(s) aren't moving their full stroke.
Old Jul 6, 2010 | 06:25 PM
714x4custom
Thanks, Yes Found it. #4 is not getting any oil as well as not moving its full stoke! Going to pull the lifter tommorow and see whats up!
Old Jul 26, 2010 | 08:00 PM
714x4custom
Looked at the lifter and it seems to be good, no groves, not rounded... Im assuming you test them by pushing on them and if they collapse or theres any play its dead? Or is there a different way to test them?
Also would this lifter cause the rockerarm galley not to get oil?
Farmboy656
Dec 17, 2014 10:18 PM
nsf3537
1997 - 2003 F150
Sep 22, 2011 05:37 PM
broncbuster
Apr 23, 2004 07:29 AM
