Firewall Insulation Pad
Old Apr 26, 2010 | 08:56 AM
BDFD's Avatar
BDFD
I'm looking to replace the firewall insulation pad under the dash. I believe I have determined that a replacement can not be sourced anywhere so I must make my own.
I've Googled a bit, searched SUmmit Racing's site, etc. and have not found a suitable material to make a new one out of. All I keep seeing are the foil-backed insulation pads, felt/fiber hood insulation materials, and the like.
I'm looking for a thick, black, rubber or vinyl backed insulator material I can use (similar to what the OEM is made out of). Any ideas on where to look or what to use?
Old Apr 26, 2010 | 01:07 PM
nstueve's Avatar
nstueve
I would suggest a MLV barrier... It's good for insulation and noise and better than OEM stuff. OEM stuff is usually cheap rubber that doesn't do much for sound and heat. I actually found a site a while back and have done a couple cars like the site suggests and you can definatly tell the difference in the cabs of our old pickups (as far as AC/HEat retention, and a heat barrier as well as noise reduction! I'd definetly go with CDL tiles closed cell foam and MLV as a tripple threat to get the best results. You can find these things on the web site below or you can find them in an online search...
I realize this site is for sound deadening your car but the products also work great for firewall insulators as well!!!!
Sound Deadener Showdown - Your Source for Sound Deadening Products and Information
Old Apr 26, 2010 | 05:02 PM
Ohio Ford Farm's Avatar
Ohio Ford Farm
LMC has this pad ( should it be the one I am thinking of ) bit pricey IMHO at like @199.95
LMC Truck Parts - Pages 40 and 41
Bottom of page 41 have a look
Tom-N
Vendor Specials, Discounts, Product Announcements & Group Buys
29
Apr 21, 2017 10:09 AM
GeneGregory
Nov 4, 2015 07:41 AM
Tom-N
Oct 13, 2015 03:56 AM
Tom-N
Oct 13, 2015 01:56 AM
Tom-N
Oct 13, 2015 01:47 AM
