Noico sound deadening materials
Hi
If you don't understand why you need this materials - you better read first this topic:
Sound Deadener and Heat Insulation – DO IT YOURSELF (DIY)
Anyone who knows what this material is and where and how to install it in the car it was quiet...You can buy the material below (under description).
I use and recommend to everyone to use these sound deadenig materials and install them in two layers – each other. Read more about this I described in the chapters about soundproofing each of the zones.
Now about the materials:
Sound deadening an <span>He</span>at insu</span>lation<span> material:
Thickness 80 mil; Total coverage area of 36 sq.feet; Number of sheets in the st<span>ac</span>k 9 ; Sheet Size 29x20 inch. Car adhesive insulation basically comprises butyl. Sound deadening Noico has a total weight of 0.65 lbs / 1 sq ft.
Noico just 80 mil $ 1.67 per 1 sqft! It is more cost-effective solution than sound deadening Dy<span>nam</span>at, Hu<span>shma</span>t, Se<span>con</span>d S<span>ki</span>n and St<span>ing</span>er R<span>oa</span>d K<span>il</span>l! Not only you buy an excellent quality product but also will save your money.
A<span>ud</span>io ins<span>ulat</span>ion N<span>oic</span>o has a special indicator of the quality of stickiness. The special embossing on the foil must be rolled out while installing, then you'll be 100% sure that the insulation is installed correctly and professionally ! The sound dampening material comes in sheets - which is convenient for installation and cutting!
Click here --> Click here --> Buy on Ebay
Every month we will publish a discount code for members of the forum
Please see below (in the message) </p>
Thickness 1/6 "( 157 mil / 4mm); Roll Size 19.7x275.6 inch; Number of roll in the st<span>ac</span>k 1; Total coverage area of 37.5 sqft; Ultra light weight
Material thickness of 1/6 inch as good as a thermal insulator and 1 i<span>nc</span>h M<span>iner</span>al or g<span>la</span>ss w<span>oo</span>l. The so<span>un</span>d de<span>ade</span>ner material allows you to deal with both the cold and the heat. HARMLESS TO HEALTH
N<span>oi</span>co L<span>ine</span>r closed cell PE foam (closed-cell polyethylene foam) the best alternative to rubber foam such as so<span>un</span>d de<span>aden</span>ing D<span>ynam</span>at D<span>ynaL</span>iner. At similar characteristics price per 1 sqft is three times less! Noise and heat insulation N<span>oic</span>o L<span>in</span>er has an adhesive layer, which makes it different from many cheap offers.
About the material you can read in detail on the company's website or on Amazon (you can buy it with delivery in 1-2 days). By the way, the forum users a discount!
You can choose other materials that are more expensive or cheap (in any case, I hope my tips will help you with this interesting fact to improve your car)
Noico inexpensive brand, but this does not mean that the quality suffers. The material is available only on Amazon and Ebay, so you wouldn't have to pay to dealers and not to pay for excessive marketing.
Why you need to choose Noico!
1. Guarantee factory quality
2. Attractive price. If you compare the materials in price approximately it turns out this equation
One pack Silver 36 sqft + one pack Liner with 37.5 sqft = one pack of Dyn<span>ama</span>t 3<span>6</span> sq<span>ft</span>
Two packs 36 sqft Silver (as much as 72 sqft) = one pack of D<span>yna</span>mat 3<span>6</span> sqft
Why pay as much and get twice as less material?
3. Positive review from those who have already used the material.
Amazon:
to enter code you need
1) Put item in the cart
2) Click the "Proceed to checkout"
3) Enter code in special form
Ebey
1) You can make us a Best offer.
2) You need to write "I drive a Ford Truck"
3) Make a discounted offer
____________________________
Useful topics:
Amazon:
Ebey
Useful topics:
- Sound Deadener and Heat Insulation – DO IT YOURSELF (DIY)
- Detailed breakdown of sound deadening process for each area of the vehicle. (plenty useful tips):
- Deadening: Floor – Firewall - Rear firewall
- Deadening: Doors
- Deadening: Roof
- Deadening: Hood
- Special: Trunk (for those who also deaden the back area in a trucks like Ford)
- How to Choose the sound deadener material?
- What is the consumption per car? How to calculate that right?
- General installation guideline. (Instructions – how to do the installation, as well as the real tips on how to make the material has fallen off, so that in it there rust, and most importantly how to get the effect)
- Pro general tips (common recommendations , articles, fun facts, important facts about insulation)
Hi!
I have a super-news. Noico now sells and rollers for stitching material.
Metal roller!!!!
It is much more reliable than wood!
The following description and link- where you can buy
Metal roller!!!!
- Noico Metal Barrel Roller is a special tool for the installation of car sound deadening materials of Dynamat, Fatmat, Gtmat brands and another sound deadener brands. The size of roller's size is barrel's width 1.3 inch = 30 mm, diameter surface 1.38 inch= 35 mm, handle length 4.33 inch = 110 mm. The roller's handle is made from plastic, the roller itself is made from metal. The roller is a must have if you want your car soundproofing be effective. The weight of the roller 1 pound
- The sound deadener Noico Roller has a corrugated surface that makes it comfortable to use and keeps it from slipping off. The roller easily moves across the surface and presses the sound deadening material to the body of your car.
- Noico Roller has a short anatomical handle so it doesn't take much effort to use it. Also due to the small size of the handle the roller is easy to apply even in hardly accessible parts of the car.
- Noico Roller is a specialized tool for Dynamat, Gtmat, Fatmat, 3M, Hushmat, Stinger and another soud deadening brands that will ensure you an effective car soundproofing . Noico Roller is the best choice for those who love their vehicle and don't want to waste their time!
- Noico Roller has a metal spinning cylinder/barrel (a part of the roller that actually rollers the material and sticks it to the car's surface). Compare to plastic, wooden and polyurethane cylinders the metal spinning cylinder works much more effectively. It's important to know that sound deadening material is made of mastic and aluminum foil not of paper as some people may thing. That 's why it's necessary to use a proper tool to roll it. Using a plastic roller for sound insulation one have to have a lot of time and patience and also it's easy to break.
Dear friends
Amazon special FEBRUARY code:
Phil2016
Amazon:
Ebay special FEBRUARY coupon:
Extra 5% off when you spend $30+ from soundcontrolproducts
how to use a coupon on Ebay:
eBay: How to redeem coupons
Spring is coming!
Phil2016
Amazon:
Spring is coming!
Dear friends
Amazon special MARCH code:
Y0URFORD
Amazon:
Ebay special MARCH coupon:
Y0URFORD
Amazon:
