2002 starter issues
Old Apr 25, 2010 | 06:54 AM
69crewcab's Avatar
69crewcab
2002 starter issues
Group my 02 is making a whizzing sound when i tried to start the truck.
Sound like starter is just spinning and not engaging the flexplate.
I had the starter tested and the starter passed by the solenoid failed.
What does the solenoid do that would not make it engage?
Or could it be something else?
Old Apr 25, 2010 | 07:58 AM
mueckster's Avatar
mueckster
A plunger inside of the starter housing is pulled down by the electromagnet in the solenoid. This plunger is attached to a yoke that pivots and pushes the starter drive forward to engage the ring gear of the flex plate. A bad starter drive/bendix, if bad, will spin when it hits the ring gear and not turn it. If the drive is moving outward from the starter front housing, then the solenoid is doing it's job as the contacts mate up inside. I hope this makes sense to you.
Name:  Starter (exploded view).gif
Item Description
1 — Thru bolts
2 — End plate
3 — Brush assembly
4 — Solenoid
5 — Lever
6 — Rear housing
7 — Front housing
8 — Drive assembly
9 — Armature assembly
10 — Frame assembly
Old Apr 26, 2010 | 06:38 AM
69crewcab's Avatar
69crewcab
mueckster
thanks!!! The drive insnt moving forward to engage the flexplate,
and now makes sense why they said the starter was good but the selenoid was bad. time for a starter
Old Apr 26, 2010 | 07:21 AM
riverrat41's Avatar
riverrat41
If that starter fits your truck fine and has been starting fine I would have it rebuilt if you have a good place around you.
Old Apr 26, 2010 | 10:06 AM
SpringerPop's Avatar
SpringerPop
I think that's very good advice. You will almost always end up with a better end result.
Pop
rpaxton939
Apr 9, 2014 08:15 PM
mOROTBREATH
18
Sep 24, 2013 07:01 PM
thelemur
Aug 23, 2013 05:23 PM
Brother Les
15
Jan 23, 2013 10:08 AM
bayslayer
Dec 5, 2011 04:26 PM
