wheel stud/rotor question?
Old Apr 24, 2010 | 11:22 PM
wareaglehey's Avatar
wareaglehey
I have a 1978 F150 full time 4wd truck. I am replacing the rotors. The problem is the holes in the rotors seem to a little too big. The rotor moves slightly on the studs. Did I get the wrong rotors or is this ok. I do not like it with the slack...just asking you guys opinions?
Old Apr 25, 2010 | 01:56 AM
tinaheels's Avatar
tinaheels
can u post a pic ?
Old Apr 25, 2010 | 11:32 AM
Greyman's Avatar
Greyman
Slight amount of clearance is necessary, but they shouldn't be sloppy on the studs. If you can grab the rotor and twist it more than an 1/16" they probably aren't the correct rotors.
Old Apr 25, 2010 | 03:01 PM
bmarkline's Avatar
bmarkline
The roter gets sandwiched between the wheel studs and the 4x4 hub. The studs press into the hub, not the rotor. They are also have a thicker diameter where they press into the hub, vs the diameter of the threads. So, if you were checking by simply slideing the rotor over the wheel studs threads while they are still mounted on the truck, it will seem sloppy.
proudtruck
17
Oct 24, 2013 09:20 PM
Brown Falcon
Oct 4, 2011 01:31 PM
kawika
Apr 14, 2007 08:52 AM
bigwalt1
Aug 11, 2004 04:37 PM
bigwalt1
Aug 11, 2004 01:42 PM
