LED lights!
Old Mar 14, 2002 | 01:24 PM
cuarch's Avatar
cuarch
LED lights!
I just installed LED tailights on my '97 Expy. As most of eveyone already knows, they draw less apms. than the normal bulbs you use. Therefore, when you hit your turn signal, the flasher relay thinks you have a bulb out, and does it's rapid flashing sequence. I have been reading on-line that you either have to replace your flasher with a new electronic flasher that can handle variable current loads or put a resistor in-line to the bulbs. Two questions to everyone.
1. Does anyone know where the turn signal flasher is located. I have check all my fuse/relay boards, and can't find it there, unless I am just not seeing it. I see the fuse to an electronic flasher, but need to locate the flasher is.
2. Has anyone already done this, and could give me advice on what to do next?
Thanks in advace,
Brandon
Old Mar 14, 2002 | 10:00 PM
2002Expy's Avatar
2002Expy
LED lights!
I ran across this article with pics on changing the flasher to an electronic one for LED's.
The gm-trucks.com site has some great pages on LED's and this was one of them. I plan to do mine after I order my 2003 X.
http://www.gm-trucks.com/IAR_ElectronicFlasher.shtml
Hope this helps you....
Old Mar 15, 2002 | 10:39 AM
cuarch's Avatar
cuarch
LED lights!
Thanks for the info. I actually came across that web-site. I found the flasher, and pulled it. Now the trouble is finding a comparable flasher that I can use. The web-site showed a Tridon flasher, but they don't make a 5 prong flasher which is what Ford uses. There is where I am having trouble now. The guys at the local parts store here have no clue what I want, so they aren't much help....so I continue my endless search.
Old Mar 15, 2002 | 04:30 PM
RJKobbeman's Avatar
RJKobbeman
LED lights!
Luke76
87
Nov 1, 2021 08:10 PM
Flame Out
Electrical Systems/Wiring
Nov 22, 2016 10:17 PM
johnkirk
41
Mar 4, 2016 02:04 AM
gpeade
2004 - 2008 F150
Dec 12, 2015 09:20 AM
FordIowan
Dec 14, 2014 09:27 AM
