duel exhaust question
i have a 94 f150 351 4wd i wanna put on tong tube headers, two high flow cats,
and two straight through perforated core mufflers. all 3''
my question is what do i get? is 3'' to big for duels on a 351?
if any of you have done this before some of the routing would be awesome
this is what i found so far
headers Hedman 89270 Hedman Headers
cat Magnaflow 94309 Magnaflow Performance Hi-Flow Catalytic Converters
muffler Magnaflow 11219 Magnaflow Performance Satin Stainless Steel Mufflers
or Cherry Bomb 87517 Cherry Bomb Glasspack Mufflers
but im not sure if the cherry bombs are perforated core or louverd
any reply are appreciated
Those Magnaflow cats are not high flows. They are ordinary 400 cpi ceramic converters. They are the same cell density as the original converters, but about 30% less cross section. That means the stock cats flow better. Magnaflow does make some high flow cats, but they are not very good in terms of theie overall quality. They work ok sometimes, but it is not uncommon for vehicles that use them to fail emissions. I have seen them come apart as well.
My suggestion is do not undermine the very nice headers you are using with a substandard converter. These would be a much better alternative.
Untitled Page
As far as the muffler, I don't like either. The Magnaflows are overpriced and are built from substandard steel. I have accumulated quite the collection of pictures of failed Magnaflows. They tend to develop stress cracks around the neck, which is one of the failure points. They use an inferior stainless. The mufflers themselves are assembled in the us out of prefabricated oriental components.
The Cherry bombs have an aggressive sound but are made from aluminized steel and tend to rot out. They are a louvered design that is more restrictive than most stock mufflers, and they get very loud very quickly as they fail.
The muffler I use myself and the ones I recommend to others are the WickedFlows. They have one of the best sounds. Its kind of hard to describe, but they just have a sound to them that no other muffler has.
Untitled Page
Untitled Page
Also using a single 3" design would you recomend using 3" from the headers through to the merge pipe? Or use the 2.5" reducers and then go up to 3" after they are merged together?
I am considering using spintech mufflers...I have done some research and it seems like they are some of the highest flowing mufflers out there, and they don't have insulation to blow out. Also their super pro mufflers are TINY!
I saw this design they did on a titan and think its really cool looking with the xpipe under the passenger side. However I don't really want to pay for two mufflers and an x and all the extra piping.
YouTube - Titan True Dual SpinTechs
I have pretty much the same setup...351W auto 4x4 ex cab.
I want to improve fuel economy, and make sure I retain my ability to tow.
