Rocker arms
Old Jan 29, 2003 | 04:19 PM
lexluthr69's Avatar
lexluthr69
Rocker arms
I am considering installing a set of roller tip rockers and was wondering if it's possible to run the 1.7 rockers vs the 1.6? and if so what other modifactions must i do in order for it to run?
I guess I should say that it's a '89 F-150 302.
Thanks
Luke
Old Feb 2, 2003 | 12:57 AM
1pump's Avatar
1pump
Rocker arms
Be careful of coil bind in your valve springs. That can get ugly.
Old Apr 27, 2004 | 01:21 AM
CROWZF150's Avatar
CROWZF150
What is coil bind?
Old Apr 27, 2004 | 12:23 PM
Missileman740's Avatar
Missileman740
Coil bind is when the spring reaches the limit of its mechanical compression. If the cam lobe is still in upward travel at this point, the weaker tensile strength of the pushrod will cause it to bend or break.
FossenRacing
Jun 4, 2012 07:24 AM
craighurst
17
Dec 31, 2010 10:46 AM
BRay09
Sep 29, 2009 08:15 PM
cowboy4x4
Apr 7, 2007 11:54 PM
mvvette97
Mar 3, 2007 08:31 AM
