hot wheel
Old Apr 23, 2010 | 09:24 AM
mollikate's Avatar
mollikate
hot wheel
I have cleaned and adjusted these brakes a time or two but still have more heat on the same wheel everytime. It is one out of 4 wheels. Tell me what i might be doing wrong.
Thanks Guys
Old Apr 23, 2010 | 11:31 AM
senix's Avatar
senix
are you running same tires all around? What type of tire and what is the size a rating?
Old Apr 23, 2010 | 03:45 PM
RV_Tech's Avatar
RV_Tech
Bearing adjusted to tightly with castle nut?
Steve
Old Apr 23, 2010 | 05:26 PM
Rugby3's Avatar
Rugby3
Thanks Guys
When you say "Clean" did you pull the caliper slide pins and clean them up then use high temp grease on em? These tend to be the #1 culprit of a dragging brake.
Old Apr 23, 2010 | 08:02 PM
mollikate's Avatar
mollikate
To the best of my abilities the bearings are all set close to same, I am running drums and tire size is 235 70 16 10 ply
Old Apr 23, 2010 | 08:17 PM
RV_Tech's Avatar
RV_Tech
So hot does it get? A little warm or too hot to touch. Just wondering if you have bearing that might be going bad.
Steve
Old Apr 23, 2010 | 08:30 PM
mollikate's Avatar
mollikate
Just a good bit warmer than others not too hot too touch
Old Apr 23, 2010 | 08:38 PM
mollikate's Avatar
mollikate
Also wondering if eletric brakes ever drag
Old Apr 23, 2010 | 08:39 PM
RV_Tech's Avatar
RV_Tech
That being the case, I am not sure it is cause for concern. My thinking is a bearing slightly out of tolerance might be the culprit. My tendency would be to keep an eye on it as see if anything changes. It doesn't sound as though there are any indication of a problem.
While in theory all the bearing should be equal in temperature, sometimes theory doesn't hold up in the real world. Most stuff seems to have a tolerance of plus or minus 10%. I wonder if this is one of those cases.
Steve
Old Apr 23, 2010 | 08:46 PM
mollikate's Avatar
mollikate
Thanks guys have a great weekend
Old Apr 23, 2010 | 08:48 PM
RV_Tech's Avatar
RV_Tech
Usually with electric brakes the problem is more likely to be not enough contact, rather than too much, but I think anything is possible. Is this something new or has it always been this way?
Steve
Old Apr 24, 2010 | 06:05 PM
mollikate's Avatar
mollikate
it is new and my dad has same problem but his is too hot to touch,I probably can handle that
Old Apr 24, 2010 | 06:28 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
If it's new, I'd schedule a trip to the dealer......
Old Apr 24, 2010 | 07:20 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
It could be that one of your magnets is grabbing onto the drum a little harder than the others causing the brake to engage a little harder.
Denny
Old Apr 25, 2010 | 06:17 AM
RV_Tech's Avatar
RV_Tech
The trouble with issues like this is it is hard to tell if they will create a problem.
If it is a brake issue, provided it can be safely done, disconnecting the brake lead to the hot wheel and taking the trailer for a spin should result in no rise in brake temperature. If you "compare the resistance between magnets on the hot wheel and one of the others, you will know if the magnets are drawing about the same amps when activated.
If the rise in temperature is still there, it would mean a bearing issue.
Either way, it is a pain in the butt!
Steve
