Chat with Chris Brewer - Mach 2
Old 04-22-2010, 01:24 PM
BigF350's Avatar
BigF350
BigF350 is offline
Ok, now that the trucks are out there, we have another chat with Chris lined up!
Chris is the Chief engineer of the truck program, and can ask all the questions you might have about the 2011
Monday April 26, 2010
Time: 1:00PM EDT
Live Chat with Chris Brewer, Ford Super Duty Chief Engineer - Live Blog Live Blogging
Old 04-22-2010, 01:41 PM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
I sure hope the people that ordered trucks, gets their truck by then. It might not be a happy time for Chris.
Old 04-22-2010, 02:10 PM
Bdox's Avatar
Bdox
Bdox is offline
This is very cool
Old 04-22-2010, 02:32 PM
EpicCowlick's Avatar
EpicCowlick
EpicCowlick is offline
Awesome! I hope the group is civil and well-behaved. Looking forward to hearing some detail on the delay and changes they've made to the trucks during the Job 1 build.
Old 04-22-2010, 04:13 PM
sammy77's Avatar
sammy77
sammy77 is offline
X2. I for one am not a very happy loyal Ford customer these days...
Old 04-23-2010, 12:44 AM
fordtruckman's Avatar
fordtruckman
fordtruckman is offline
It would be awesome if the designers/engineers that work at Ford would join this site and be able to see the feedback directly from the customer.
Old 04-23-2010, 12:53 AM
Bdox's Avatar
Bdox
Bdox is offline
I believe that is exactly what this thread is all about!
Old 04-23-2010, 10:56 AM
Danger_Dave's Avatar
Danger_Dave
Danger_Dave is offline
whats bizarre to me is how none of these super duty trucks or even the f150 come with a manual transmission. every single one of them has an automatic.
Old 04-23-2010, 11:22 AM
EpicCowlick
Ford did away with the manual transmission option in 2011. Apparently just not enough demand (something like 1 - 3%?). In the 6R100 they offer a manual mode which allows the driver to use a +/- control on the shifter to go through the gears manually. GM also has no manual transmission option in 2011. Only Dodge will offer that.
Old 04-23-2010, 12:32 PM
BigF350's Avatar
BigF350
BigF350 is offline
Perhaps you missed these threads?
Our previous chat with Chris:
Interview with Ford Chief Engineer: Chris Brewer .: Articles
Peter (Superduty Engineering Manager) discussing the overall 2011 SD
https://www.ford-trucks.com/forums/9...e-welcome.html
Adam (6.7 chief engineer) discussing the new 6.7 PSD
https://www.ford-trucks.com/forums/9...oining-us.html
Mike (6.2 chief engineer) discussing the new 6.2 V8
https://www.ford-trucks.com/forums/9...as-engine.html
Old 04-23-2010, 12:36 PM
BigF350's Avatar
BigF350
BigF350 is offline
One of the Ford gentleman mentioned that the take rate was just too low to justify a business case for it. The fact that GM was dropping their manual trans was the proverbial nail in the coffin.
I think its disappointing - I can't foresee myself ever owning an automatic truck (for practical and personal preference reasons), but I can understand the move, I haven't seen another manual trans SD in SoCal outside of mine.
Old 04-23-2010, 12:51 PM
gearloose1's Avatar
gearloose1
gearloose1 is offline
I am not going to make it to the chat.
Will someone raise this issue with Ford?
Honda developed a exhaust treatment system that do not require Diesel Exhaust Fluid to be added.
Here are the details:
Reaction Mechanism of the New NOx Catalytic Converter for Diesel Engines
1: During lean burn operation, the NOx adsorbent in the lower layer adsorbs NOx from the exhaust gas.
2: As needed, the engine management system adjusts the engine air-fuel ratio to rich-burn, wherein the NOx in the NOx adsorption layer reacts with hydrogen (H2) obtained from the exhaust gas to produce ammonia (NH3). The adsorbent material in the upper layer temporarily adsorbs the NH3.
3: When the engine returns to lean-burn operation, NH3 adsorbed in the upper layer reacts with NOx in the exhaust gas and reduces it to harmless nitrogen (N2).
Exhaust Gas Cleaning System Configuration
Source: Honda Motor Co., Ltd.
Honda Develops Next-Generation Clean Diesel Engine - Honda.com
The system is elegant, and nearly maintenance free.
Why not license the system from Honda?
Old 04-23-2010, 09:03 PM
fordtruckman
Indeed I did Thanks.
Old 04-24-2010, 01:20 PM
Rodrigo Lopez's Avatar
Rodrigo Lopez
Rodrigo Lopez is offline
Where can I get power+torque curves for Ford V10 6.8L gas engines and Ford V8 5.4L gas engine?
Old 04-25-2010, 09:07 AM
Tom's Avatar
Tom
Tom is offline
This sounds remarkably similar to the system Dodge uses on it's trucks. Called a NOx adsorber or Lean NOx Trap(LNT).
Chrysler Diesel Exhaust Fluid System Previews NOx Reduction Solutions for 2010 - PickupTrucks.com News
The downside, as I understand it, is that like a DPF, this technology has to be regenerated in a similar manner. Meaning that the engine cycles between running lean and rich all the time based on a sensor, which requires wasting lots of fuel!
As far as I can tell the system, when used on the CTD, is less efficient than the current generation 6.4L PSD. SCR allows them to tune the engine to use less EGR and a more efficient combustion cycle while still meeting NOx standards.
LNT technology may be easier to use, but it doesn't deliver one of the biggest expectations customers have for these new trucks: fuel economy!
Quick Reply: Chat with Chris Brewer - Mach 2
