Sponsored by: Real Truck
2004 6.0 coolant/temp problem
Old Apr 22, 2010 | 05:36 AM
backspace's Avatar
backspace
Anyone with suggestions. I have a 2004 6.0 and when I get it under a load the fan starts kicking in and out eventually staying on. Usually runs steady after about 20 miles. I also start getting a coolant smell off and on. The temp gauges stay steady and never seen them climb above normal? I want to have it looked at but would like some idea of what it is because there are not many trustworthy mechanics in my area.
Old Apr 22, 2010 | 05:58 AM
fordtech08's Avatar
fordtech08
could be your fan clutch, egr cooler& oil cooler, head gaskets, radiator hard to say with out seeing it most likely egr cooler
Old Apr 22, 2010 | 06:32 AM
backspace's Avatar
backspace
I have been told the egr cooler is likely cause, but if it's that could I still the coolant smell upfront or would it be going out exhaust? Any troubleshooting tips I could preform before going to shop?
Old Apr 22, 2010 | 08:48 AM
fordtech08's Avatar
fordtech08
look at your degas bottle is there white color around the lid? also have you been filling the coolant all the way to the top or to the low mark ( the low mark on the bottle is actually the full mark)
Old Apr 22, 2010 | 08:55 AM
gearloose1's Avatar
gearloose1
Check for a coolant leak:
- all hoses and clamps, radiator, including the heater inside!!!!
- if you have a coolant that shows up under UV, use a UV light.
Try to localize the odor.
2004_6.0 powerstroke
Oct 21, 2014 08:52 PM
RickBraden
Apr 14, 2013 06:09 PM
ten.mile
Feb 13, 2013 11:58 PM
carmk
Apr 18, 2012 08:27 AM
calvinscott20004
Mar 24, 2010 10:26 AM
