adding cruise control
Old Apr 21, 2010 | 05:41 PM
wpbcobra's Avatar
wpbcobra
hello i am adding cruise on my 95 F250. I got the steering wheel with the buttons in it and the box that gose under the hood. I connected them up and dint work. Is there something i am missing or still need to do. thank you for ur help
Old Apr 22, 2010 | 12:17 PM
wpbcobra's Avatar
wpbcobra
bump bump..
Old Apr 22, 2010 | 01:26 PM
rla2005's Avatar
rla2005
I am surprised the wires/connectors were there. You will also need the pressure switch located near the master cylinder. This is the piece that was part of the cruise control recall. It's a pressure switch and adapter that taps into the brake line. This is what tells the PCM to disengage. I do not have any photos for it. My '92 F350 and previous two '93 Lightnings has a slightly different setup than your '95.
Old Apr 22, 2010 | 02:22 PM
wpbcobra's Avatar
wpbcobra
dose anybody have a pic of where the switch is. I thought it was a plug in and work kinda of things on these years. thank you
Old Apr 23, 2010 | 11:48 AM
wpbcobra's Avatar
wpbcobra
bump bump bump
Old Apr 23, 2010 | 01:58 PM
rla2005's Avatar
rla2005
This might help:
This shows the pressure switch connector after the Ford recall was done.
Old Apr 23, 2010 | 02:34 PM
wpbcobra's Avatar
wpbcobra
mine dont look like that i dont have the switch like that. here is a pic of what mine looks like. Since i dont have that will the cruise work or do i have to change the hole brake system thank you
Old Apr 23, 2010 | 03:25 PM
BCHauler's Avatar
BCHauler
According to my LMC catalog, there are different part numbers for the master cylinder, depending on with cruise control or without.
Old Apr 23, 2010 | 04:50 PM
wpbcobra's Avatar
wpbcobra
ok so i am not going to be able to put in cruise unless i change the brake system
Old Apr 25, 2010 | 11:08 PM
wpbcobra's Avatar
wpbcobra
bump bump bump
Old Apr 28, 2010 | 11:36 AM
wpbcobra's Avatar
wpbcobra
any suggestions on what i would have to do to install cruise now thank you
Old Apr 28, 2010 | 12:37 PM
BCHauler's Avatar
BCHauler
Well for starters, you will likely need to change your master cylinder...
Old Apr 28, 2010 | 03:07 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
What about old cruise control style?
My 91 Bronco have cruise control but not have sensor on master cylinder.
I am watch this since my 95 F250 didn't came with cruise control
Old May 1, 2010 | 11:21 PM
wpbcobra's Avatar
wpbcobra
be for i buy a new master with the switch on it. dose anybody know if the truck would have the connector for the switch allready installed on the truck
Old May 2, 2010 | 08:24 AM
rla2005's Avatar
rla2005
This link: How the Circuit Works is a description from an EVTM manual for a 1986 Ford truck. The cruise control system is basically the same for your '91 Bronco (and my '92 F-350). It uses a vacuum servo instead of the electronic style the later models used. From what I can tell the brake light switch also disengages the cruise. Quite a bit different from the later model cruise control that use a separate switch mounted on the brake lines.
Electrical diagram:Speed Control
