Front Differential oil?
I recently added a mag hytec cover to the sterling 10.5 rear. I used the recommended royal purple 75w-140. I am now replacing the front differential cover and I am not quite sure if using the same grade of gear oil is correct or 75w-90? Any advice?
I have read the owner's manual and it said 75w or 80w-90 i can not remember.... however, the mag hytec instructions called for 140... same as rear diff. I will follow w/ 75w-90. Thanks for the replies.
There is really good stuff in the tech folder.
Welcome to guzzle's Front Differential Maintenance Web Page
Hey guys, while we're on the subject, I'm doing both front & rear mag hytec swaps this weekend. Any idea how many quarts the front & rear hold? 03 250 SD.
**Nevermind** - should have checked Guzzles website first, already answered my own question.
Anyway, the Mag-Hytec site has info:
http://www.mag-hytec.com/Ford%20Diff...2-10.25_.5.pdf
http://www.mag-hytec.com/Ford%20Diff...2050_60-FF.pdf
They have the wrong oil recommendation for the front, which has been noticed by others. So use the Ford lube spec, and the Mag-Hytec quantity.
Just curious why you would put a mag hytec on the front diff? I can't see any benefit from it unless you ride down the highway towing a load in 4wd.
When I changed the oil in mine the rear definitely looked like it had been "used" but the front looked like I just drove it off the dealers lot.
This was after 70K on the clock and I use the 4WD weekly on jobsites.
I just replaced the front yesterday. Easy installation on both. 1st question answer is 5 quarts only in the rear diff and just under 4 quarts in the front. 2nd question answer is I chose mag hytec for the look and assurance. The astetics are awesome. I will try and post pics. But the biggest reason is maintenance. I like being able to check the fluids w/ the dip stick. Also, as long as the oring seal holds.... I will never have to go through the messy process of pealing the cover off. The rtv sealant used on the oem covers is a pain. W/ mag hytec covers they have a drain plug...plus the dipstick and drain plug are very strong magnets that will collect the normal metal particles that are generated over time. The downside is that I paid over $250 each diff cover and $17.99 a qt of royal purple oil. 9 qt total. however iam very pleased w/ it and 2morrow iam installing a fox dual stabilizer kit that ought to look great w/ the cover. BTW.... the rear oil at 50,000 miles was a lil burnt and the front was very clean.
I'll bet it looks sharp, although I agree it is for appearance more than application. Nothing wrong with that.
