They want 400 for it as is. 450 if I take the leaf springs with it. It's missing the spindles out (was a dually originally so I figure someone grabbed 'em for dually) and drivers side driveshaft. This would be a junkyard pull. I realize it'll take about 600-700 bucks to piece it all together so looking at likely about 1,200 bucks all said and done, which seems about right from what I've read about it usually being a 1,200-1,500 dollar swap.
Your rims might not have a large enough center hole to accommodate the larger hub. Mine didn't. Had to grind out the center hole with the angle grinder to get it to fit flush over the hub.
