D60 confusion..
Old Apr 21, 2010 | 12:40 PM
swooshcmk's Avatar
swooshcmk
D60 confusion..
Ok I know this is kinda O.T. for this form but I've seen it mentioned here before and I know a few of you guys have done it..
I've got an '85 F250 gasser. I'm not sure if that means I have a D44HD or D50 TTB? I haven't found a real definitive way to tell either yet. Is there an identifier on it somewhere? She's all greasy
I plan to do a D60 swap - are any parts of a D44HD/D50 TTB setup compatible with the D60?
Local junkyard has a D60 front end from a '90 F350. I haven't seen it yet but I guess it's missing the left/right spindles and the passenger axle. I think i read somewhere that the D44HD/D50TTB and D60 used all the same outters up until the ball joints in 91 on the D60 - is that right? It wouldn't be too bad if I could swap my outers over and only needed an axle...???
What's a D60 missing passenger axle and the outer spindles worth?
I think I'm going crazy here!
Thanks guys!
Old Apr 21, 2010 | 01:54 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
The lock hubs on a D44 are about the same size as the wheel hub, the D50 the Wheel hub is larger than the lock hub...
There are pictures in the 80-86 Forum stickies.
-Enjoy
fh : )_~
Old Apr 21, 2010 | 04:34 PM
swooshcmk's Avatar
swooshcmk
Thanks for the info. Though I must be blind though as I'm not seeing anything in the 80-86 stickies... I'll take a look when I get home though and see if I can figure out what it is.
Is it true that the D44HD/D50 and D60 outer are all the same?
Chris
Old Apr 21, 2010 | 07:57 PM
swooshcmk's Avatar
swooshcmk
So this would mean I have a D44HD right??
And so do I have some or none parts interchangeability with a D60???
Chris
Old Apr 21, 2010 | 09:11 PM
greywynd's Avatar
greywynd
Your rims and tires will bolt on directly. Axles are different, u joints are different, hubs are larger on a D60, as mentioned previously. Calipers and rotors I'm not sure on, I think the calipers will work on either, but nor certain, and can't tell you about the rotors at all.
Old Apr 21, 2010 | 09:43 PM
1994F2507.3L's Avatar
1994F2507.3L
my dana 50 has a big 50 on the back side of the pumpkin youll need to wash it off a little first to probably see it
Old Apr 21, 2010 | 10:11 PM
Festus Hagen
Methanoholic
Well Bite my tongue ... I thought it was there, I'll see if I can find it and have it added.
Sorry for the mislead.
-Enjoy
fh : )_~
Old Apr 22, 2010 | 12:18 AM
91dirtydiesel's Avatar
91dirtydiesel
Chris
i know the d50 is the same as the 60 for sure not sure bout the 44 though, i dont think it is, im pretty sure i used a different spindle nut socket last time i worked on a 44
Old Apr 22, 2010 | 03:40 AM
RCrawler's Avatar
RCrawler
You have a Dana 44. The 44 has a 3.5" diameter hub. The 50 and 60 have a
4" diameter hub. Unfortunately, none of your parts will interchange with a 60.
Few parts interchange between the 50 and 60. Wheel bearings, out to the locking hub are about it. Spindles are different, as I recall.
Jason
Old Apr 22, 2010 | 04:04 AM
Skip1970's Avatar
Skip1970
yep 44 yuk!
Old Apr 22, 2010 | 10:25 AM
rodneywar's Avatar
rodneywar
spindles on a d50 and d60 will interchange!!
Old Apr 22, 2010 | 10:26 AM
rodneywar's Avatar
rodneywar
my parts from the spindle out not the axle are from my old d50 when i sasd the truck
Old Apr 22, 2010 | 04:15 PM
swooshcmk's Avatar
swooshcmk
Thanks for all the info guys, it's all fairly clear now!
Are the warn locking hubs different too then? It would seem to me if D50/D60 hubs are larger than the locking hub and D44 is same size that it would be the same? Or is that some more parts I'll need to source?
If I get the local D60 I'll need spindles, hubs, drivers side axle and drag link/tie rods because some monkey bent them up somehow... This truck is getting expensive lol
Thanks!
Old Apr 22, 2010 | 05:18 PM
rodneywar's Avatar
rodneywar
the warn hubs are the same on the 50 and 60 but different on the 44
Old Apr 23, 2010 | 02:19 AM
RCrawler's Avatar
RCrawler
How much are you paying for this D60?
Jason
