steering problem
Old Apr 21, 2010 | 10:20 AM
IsoGrifo's Avatar
IsoGrifo
Exclamation steering problem
Hey guys,
A couple days ago I discovered while making a quick right turn (Sliding a little bit ) that the steering wheel gets stuck sometimes! In trying to make it do it, I can only get it to do this in quick right turns. Lefts fine and if I'm not driving like a donkey it's fine. But it still raises a bit of concern, let me try to explain it... you know how when you turn the wheel and when you let off it's supposed to go back to center, in these turns it won't return and I kinda have to yank the wheel back, it's not a full on lock into place, just gets kinda hung up on something.
Anyways, has anyone ever run into this or have any idea what could be causing it? Once I get new tires I'm gonna take it to a suspension shop and have the alignment all checked out and make sure all the suspension parts are tight, and while I'm there I might want to see if they can fix it.
Old Apr 21, 2010 | 10:52 AM
Bdox's Avatar
Bdox
Check the caster angle on the right side. Other than that, there may be some worn steering parts.
Old Apr 22, 2010 | 02:19 AM
IsoGrifo's Avatar
IsoGrifo
front left spindle is loose! figured it out today when I was able to move the wheel with the truck staying still! and yes I checked my lug nuts...
which would make sense, there's more force on the left side in a right hand turn.
Old Apr 24, 2010 | 05:15 PM
IsoGrifo's Avatar
IsoGrifo
well the spindle was loose, but the reason it was loose is because the bearings are shot!
So I tightened it up as much as I could just to get me moving and a little safer, but probably next weekend I gotta replace the bearings, anyone know about how much a bearing press is?
Old Apr 25, 2010 | 05:43 AM
powersmoked's Avatar
powersmoked
well it is early here and maybe I am half asleep, but is this for a Ford Ranger. I just changed the wheel bearings on my 2wd, it is straight forward. I thought some of the 4wd had sealed unit that you replace....some of them have an abs senosr in them......I think......gonna get some coffee
Old Apr 25, 2010 | 12:11 PM
IsoGrifo's Avatar
IsoGrifo
powersmoked, coffee sounds like exactly what you need! cuz that made absolutely no sense, lol
Old Apr 25, 2010 | 12:36 PM
powersmoked
Whay rear is your ranger? Is it 2wd or 4wd?
Old Apr 25, 2010 | 12:52 PM
powersmoked
I see you have a 92 ranger is it 2wd or 4wd? where do you press the bearings into.......on mine you could press new races into the rotor but I was replacing my rotors and they came with new races.......maybe the 4wd is different..... I like learning new things about these trucks.thanks for educating me.....
Old Apr 25, 2010 | 07:17 PM
IsoGrifo's Avatar
IsoGrifo
it is a 2wd
The PO put at least one new rotor in but I know he didn't put in new bearings, so I at least one new race and both inners and outers.
I'm not gonna worry about the rears for now.
Old Apr 25, 2010 | 07:36 PM
powersmoked
Copy-that, 10-4, yo comprende
Old Apr 25, 2010 | 10:25 PM
Bdox's Avatar
Bdox
Iso, if you need to change a bearing, always change the race that it mates with. If a race is bad, alway change the race and bearing together!!!
Old Apr 26, 2010 | 12:21 AM
IsoGrifo's Avatar
IsoGrifo
even if said race has about 1500 on it with a bad bearing?
Old Apr 26, 2010 | 12:34 AM
Bdox's Avatar
Bdox
If a race has had a bad bearing running on it, the likelyhood of it being damaged is very high.
doublecanister
17
Jun 26, 2014 02:09 PM
xjcamaro89
2004 - 2008 F150
Aug 21, 2012 03:39 PM
Jaxxe
Nov 4, 2011 04:26 PM
EXv10
Dec 13, 2009 11:03 PM
Redmanbob
19
Feb 2, 2009 02:56 PM
