Sponsored by: Real Truck
Bilstien Shock Question
Old Apr 21, 2010 | 07:30 AM
bakon's Avatar
bakon
Putting new Bilstein shocks on my 2003 SD350 4x4. The shocks came with no instructions and website was no help. I then called the east coast and west coast offices. Two different answers. actually three, with the last being boot down.
Do the rubber boots on the shocks go up or down?
The shocks are yellow with blue boots. They only fit with the boot down, part number have 2818 and 2819 on end and were heavy duty models. The only other thing was box listed F250 not F350 but I believe that should not matter, both summit racing and bilstein site list them for F350 4x4.
Old Apr 21, 2010 | 10:12 AM
ncon's Avatar
ncon
Hey Bakon,
Yes, boots down is how I installed them without any issues, mounted such that the label is readable.
As a side note, I just sent in my 100k mi front Bilstien's for "evaluation" / warranty replacement...I'll let everyone know how that goes!
ncon
Old Apr 21, 2010 | 10:23 AM
rickf92592's Avatar
rickf92592
In theory it doesn't matter but, yes, boot down is the preferred install so dirt/dust/moisture tends to fall away from the seal rather than sit on it.
BTW, the boots are vented, (have to be or they'd blow up) and are only meant to keep stuff from hitting the shafts.
Old Apr 21, 2010 | 12:50 PM
bakon's Avatar
bakon
The label on the rears was upright when installed. It was the front the label was upside down installed with the boot down. One person at east coast office said, install them so you can read them. That would be boot up but they dont fit the stud up top that way. Flipped over, label upside down, boot down, stud and bottom bolt fit.
Did see the vents and thought they should be down too, drain out water. I did not consider debris sitting on the seal, but boot down would eliminate that too.
Old Apr 22, 2010 | 12:11 PM
bakon's Avatar
bakon
Anyone else. Believe what was posted so far but a post or two more saying it was fine would make me feel better. Thanks
Old Apr 22, 2010 | 12:35 PM
ncon's Avatar
ncon
I'm surprised it didn't fit in either way, in my 99 250 they do, but with that vented boot for sure down. I have Bilstiens on the wife's jeep that have a cup shaped blue boot, open to the large end of the shock, and these mount only in the "boot upward" scenario (rears)...and it makes sense as that type boot would not hold water in there.
Roughcountry has dual shock brackets for about $80, thinking about running 2...if Bilstien gives me the warranty replacements!
Your gonna love new front shocks!
Old Apr 22, 2010 | 12:39 PM
bakon's Avatar
bakon
Why run two in the front? Offroad use?
Old Apr 22, 2010 | 12:45 PM
rickf92592's Avatar
rickf92592
Those fade really fast off-road.
Old Apr 22, 2010 | 12:57 PM
ncon's Avatar
ncon
road use, thinking 2 would be better than 1, and maybe last longer too!?
Old Apr 22, 2010 | 01:03 PM
GUNNERDOG's Avatar
GUNNERDOG
Mine fronts are "upside down" too. I tried to install them boot up, but like you said, they wouldn't fit. My lables are right side up with the shock installed boot down.
Old Apr 23, 2010 | 07:30 AM
bakon's Avatar
bakon
I wish my labels were. Then I wouldn't have this question. Thanks for replies.
Old Apr 29, 2010 | 08:35 PM
ncon's Avatar
ncon
Bilstein approved free warranty replacements on my 100Kmi 5100's today, I'm happy to report. Thanks for the comments on dual shocks, I decided to stick with the new single stock setup for now. It's a night and day difference with the new shocks in there!
Old Apr 29, 2010 | 10:30 PM
warmdye's Avatar
warmdye
My labels are upside down with the boot down.
Old Apr 29, 2010 | 11:12 PM
DAVE67FD's Avatar
DAVE67FD
ncon,
Explain how you got a 100k warranty on the 5100's which have no warranty. You sure your not refering to the HD series?
Old Apr 30, 2010 | 07:10 AM
ncon's Avatar
ncon
My error Dave, they are HD series Bilstiens.
I am very happy they honored the warrenty,
as they weren't leaking or damaged...just weren't
performing well anymore.
Thanks,
Neil
