Need help with steering issue.
Old Apr 20, 2010 | 07:15 PM
1962 custom100's Avatar
1962 custom100
I have whati believe to be a 1966 mercury f100 custom cab with the "famous" twin I beam suspension. Id love to drive this but cant. It is nearly imposible to steer. What the truck does is when you turn it will turn goof for 1/4 of a revolution and then get harder and harder to turn.
Then if you continue to turn it the steering goes bang! and the entire cab shakes. after spending 3 hours i nearly have the coloum taken apart and i think i have found the problem. now on my steering where the top of the steering meets the steering shaft in between this there is a rubber piece of some sort. the holes are stretched and when your turn it this piece flexes and binds up upon it self. this is what i think is the problem. Does any one know of a website i can order this parts from and has any one had a similar problem?
Thanks ahead of time i am very very new to this old old truck. especially fords
Old Apr 20, 2010 | 08:18 PM
Bill W's Avatar
Bill W
It is called a rag joint, and i bet Dennis Carpenter has them, also try LMC and Mac's may even Blue Oval truck parts
Old Apr 20, 2010 | 08:25 PM
Customcab's Avatar
Customcab
Its a 10 dollar item at bascially any auto parts store; as Bill W mention (Rag Joint)
I recommend replacing asap; once it breaks completely you will have no steering.(Very dangerous situation while driving) The rag / rubber joint is ciricular and aglines on the steering rod; Its held on by two 1/2 nut; between the steering box & steering rod (column) inside the engine bay.
Just the help isle at any auto parts store; or ask a clerk!
Mitch
Old Apr 20, 2010 | 08:30 PM
OldHarley's Avatar
OldHarley
In answer to your question, Autozone carries this rubber part in their 'Help' section. It is called a rag joint and sells for about $8. Kit comes with new bolts, etc.
However, I have my doubts that this will fix your problem. You really need to get a buddy under the hood to watch while you turn the wheel. I think something else serious is going on down there, possibly with the steering box.
Once you figure out what is causing this 'bang' and what exactly precedes it, give a description and you should be able to get better help.
Also, if this is not a '66 Mercury truck twin I, as you suspect, but a '62, like your screen name, it has completely different steering setup than I have described.
Old Apr 20, 2010 | 09:38 PM
Old_Crow's Avatar
Old_Crow
Might take a look under it at the cab mounts. I've heard that if they're rusted the front of the cab can settle and cause weird goings on with the steering.
Old Apr 20, 2010 | 10:16 PM
1962 custom100
I do also think it may be the sterring box but for 8 bucks i will try this first. after taking most of the sterring coloum i found everything to be worn to hell . i will install a new rag joint and see if this helps or fixes the problem. if it dosent then a new steering box will be installed. is there any way FOR SURE i can tell the year of the vehicle. some people say its a 66 some say a 62. It has a frame and isnt the unibody , hope this helps.
Thanks for all the great info guys! i will report back!
Old Apr 20, 2010 | 10:21 PM
1962 custom100
front left cab mount is rusted , how would this cause steering problems?
Old Apr 20, 2010 | 11:11 PM
garbz2's Avatar
garbz2
It puts all the weight of the cab on the steering column and steering box. Creates all kinds of funky movement and breaks things.
Aftermarket rag joints are fine but the steering shaft needs to be modified to accommodate the later large pin each side rag joint. 65 66 is stock small pin large pin. A grinder will take enough off the steering flange to match the large large size. No one make a 65 66 specific rag joint.
Garbz
Old Apr 21, 2010 | 12:03 AM
1962 custom100
Garbz
Whats the best way to stop this for now? it will be getting fixed but is there a way to take any weight off the steering colom to see if this is indeed th problem?
Old Apr 21, 2010 | 12:05 AM
garbz2's Avatar
garbz2
I have seen 2x4s stuffed in for shims. Only real way to fix it is replace them and the rubber cab insulators.
Garbz
Old Apr 21, 2010 | 05:28 PM
1962 custom100
Can any one tell me where i might be able to get a steering coloum for this?, or will a differnt steering coloum from a slight newer international fit on it?
Old Apr 21, 2010 | 08:35 PM
Customcab's Avatar
Customcab
I can't crunch numbers like some on here; but a 61-64 F100 & I beleive 4x4 up to 66; are the same. You can modify your fire wall to adapt a 65-79 style. But if you do; I also recommend going the extra mile and add power steering as well.
Check you local salvage yards and the classified here as well.
Where are you located at? might have a local FTE'r near by!
Mitch
Old Apr 21, 2010 | 08:37 PM
OldHarley's Avatar
OldHarley
No one knows what might fit until we have an idea of what you are working on.
Could you post a pic? First of the truck, to determine what year you have and then the description of the problem with a pic of the steering.
Somebody here will know. Not sure who is familiar with International truck parts. BUT, I think that after he fought in the Civil War, NumberDummy was an International partsman for a few years before he went to Ford.
Old Apr 21, 2010 | 10:21 PM
1962 custom100
Alright ill try and post some pictures for yall tommorw
Old Apr 21, 2010 | 10:24 PM
1962 custom100
Mitch
I live in Regina Saskatchewan
