Sponsored by: Real Truck
REAR BRAKE DRAGGING?
Old Apr 20, 2010 | 01:46 PM
artfuldodger's Avatar
artfuldodger
I arrived at the dealer's a few minues ago for a routine transmission fluid and filter change. When I got out of the truck(F350 6.0 diesel) I could smell brake lining and sure enoough the rim on the passenger rear was quite warm, if not hot. i think the caliper must be dragging. there was no pulling to one side but is this a routine occurance with this truck? I haven't had a bad caliper since the early eighties.
Old Apr 20, 2010 | 01:54 PM
mwsF250's Avatar
mwsF250
Incident rate seems to be about the same as any other vehicle.
Was it the caliper dragging, or the parking brake?
As with any vehicle, PM is secret to avoiding problems.
- Flush brake fluid every 2 years to prevent corrosion in caliper
- Clean/regrease slide pins and parking brake linkages every 5 years. Much more frequently if driven in very wet conditions, or where roads are salted.
Old Apr 20, 2010 | 02:01 PM
artfuldodger
I haven't used the parking brake lately so I figured its got to be the caliper. Anyways, its time to pull the wheel and take a look I guess.
Old Apr 20, 2010 | 02:02 PM
gearloose1's Avatar
gearloose1
Annual / biannual is the frequency needed in high road salt / corrosion places.
Old Apr 20, 2010 | 03:04 PM
mikesmayhem's Avatar
mikesmayhem
I had to take a hammer to help loosen my parking brake because it waas dragging a little.
Old Apr 20, 2010 | 08:09 PM
815 BLADE's Avatar
815 BLADE
I had the same problem with my 2008 F250.Turned out to be a defective caliper that ford warranteed. Truck had about 35K on her when that happened.
Old Apr 20, 2010 | 10:22 PM
DAVE67FD's Avatar
DAVE67FD
It's typically the slide pins. I have had 3 out of 4 calipers replaced on my 06 under warranty. If their not frozen then clean them well and apply the high temp teflon grease.
Havas E
2004 - 2008 F150
21
Jul 8, 2018 05:16 PM
bach44
General Automotive Discussion
Jan 26, 2015 12:00 AM
MC5C
Dec 12, 2014 02:41 PM
alchemist1
Mar 17, 2014 08:54 PM
TCLyford
Dec 7, 2013 09:01 AM
