brakes dragging
Old Dec 7, 2013 | 07:22 AM
TCLyford's Avatar
TCLyford
brakes dragging
Replaced all calipers this summer.Rear brakes are dragging again. R/R caliper had to replaced again. Is there something I should know about bleeding these brakes or just getting crap calipers? '06 F350
Old Dec 7, 2013 | 08:00 AM
Shaneb75's Avatar
Shaneb75
Strokin Okie
I have not had any issues with calipers hanging up personally, but I can tell you I flush my brake system every couple of years too.
I evacuate the fluid out of the resevoir first, and refill with fresh fluid. The start at the furthest wheel from the resevoir and work your way to the drivers wheel. Once you get the hang of it, can flush a system in 15-20 minutes.
Here is the best 100.00 you will spend!
MV7300 PneumatiVac
Amazon.com: Mityvac 7300 PneumatiVac Air-Operated Fluid Evacuator: Automotive Amazon.com: Mityvac 7300 PneumatiVac Air-Operated Fluid Evacuator: Automotive
Old Dec 7, 2013 | 08:26 AM
npccpartsman's Avatar
npccpartsman
Did you install new hardware with the calipers? Are you sure it's not in the parking brake system?
Personally I like these for "changing" brake fluid: Russell Performance - Domestic Speed Bleeders
You can install and self bleed the whole system in <30 minutes initially and I got mine for $40 shipped to the house. Never had brake pedal this good!!
Old Dec 7, 2013 | 08:29 AM
MisterCMK's Avatar
MisterCMK
Do you have a part number?
Sent from my mind thanks to the Internet and an app.
Old Dec 7, 2013 | 08:33 AM
npccpartsman
99-04 F-250 4WD Super Duty 639560 639560 – –
05-06 F-250 4WD Super Duty 639590 639590 – –
68-94 F-350 639510 – – 639590
95-97 F-350 639590 – – 639590
99-04 F-350 4WD Super Duty 639560 639560 – –
05-06 F-350 4WD Super Duty 639590 639590
There are basically only 2 different numbers--same front and rear though
Old Dec 7, 2013 | 09:01 AM
MisterCMK's Avatar
MisterCMK
Thanks. Looks like 639590 for my truck.
hotwtr
Nov 17, 2009 06:58 PM
flip1950
Oct 24, 2009 03:17 PM
crazyrwe
Escape & Escape Hybrid
Nov 6, 2006 03:39 PM
Big Rig
Modular V10 (6.8l)
Oct 7, 2006 08:09 AM
BiodieselPanther
1983 - 2012 Ranger & B-Series
Jan 13, 2006 09:12 PM
