2002 7.3 Ex front bump stops
Old Apr 20, 2010 | 09:53 AM
aero993's Avatar
aero993
While replacing the shocks on my truck. I noticed that one bump stop was completely gone. The other appears to be on it's last leg. Is this an item that most get from the stealership or aftermarket? If aftermaket which brand is preferred?
Thanks
Old Apr 20, 2010 | 11:40 AM
rlh68050's Avatar
rlh68050
Mine did that too. Got them from the dealer.
Old Apr 20, 2010 | 11:58 AM
X-Hibition's Avatar
X-Hibition
And how much room do you have between the bump stop and the spring?
Is it spring time?
It will keep you from having to replace the bump stops so often and give you a better ride. You know that 7.3 isn't exactly light...
Old Apr 20, 2010 | 01:37 PM
aero993's Avatar
aero993
Maybe I'm calling it the wrong name. What I'm talking about has bolts on each side and is attached to the frame. I saw no springs anywhere near it. I guess I'll have to take a picture.
Old Apr 20, 2010 | 01:54 PM
X-Hibition's Avatar
X-Hibition
You are talking about the bump stop. It does bolt to the frame and hits the top of the spring perch when you bottom out the front suspension. That is what chews them up, and with very limited suspension travel in the front (stock) it is easy to do.
Old Apr 21, 2010 | 08:27 AM
njstevens's Avatar
njstevens
Aero993 those are bump stops and usually they will crumble away once you crack them by bottoming out your 7.3 x. You can get aftermarket or go to stealership to get new ones. But as X-hIBITION said is it spring time. Are the soriginal springs on your truck still? If so i am going to say you are in need of new springs definately. YOu also might want to consider an upgrade on the springs that will allow slightly more travel so you are not bottoming out. I am not saying to jack her all the way up but get some additional clearance as that 7.3 motor is heavy as stated previously,.
jrockdiddy
33
Mar 6, 2014 05:21 PM
nagetech
Feb 20, 2014 06:27 PM
kconrad
Mar 27, 2012 05:17 PM
wreedZ71
2004 - 2008 F150
May 11, 2010 01:42 PM
birdman127
Sep 6, 2003 10:36 AM
