Where to support the frame when jacking-up?
Old Apr 13, 2010 | 08:36 AM
blowhole's Avatar
blowhole
If I am jacking up the front end, or either end for that matter, where is the best place to support the Ex by the frame? I have 4-ton stands.
Old Apr 18, 2010 | 09:56 PM
delzy's Avatar
delzy
Under the frame.
Old Apr 20, 2010 | 10:57 PM
blowhole's Avatar
blowhole
Originally Posted by delzy
Under the frame.
Nice!!
Anywhere specific, under the frame??
Old Apr 21, 2010 | 06:39 AM
tdappleman's Avatar
tdappleman
Pick any flat spot near the end of the frame rails which will allow you to enough room to have the jack stand in place and allows the truck to be balanced. You also will need room for the jack to be moved around as you take it from side to side or front to rear. On a lift I use the frame just behind the front leaf spring shackle and just in front of the rear leaf spring.
Old Apr 21, 2010 | 08:43 AM
blowhole's Avatar
blowhole
Perfect - that is what I wanted to hear. Thanks, reps given!
FireEngineMike
1947 and Older Ford Trucks
Nov 9, 2016 08:52 PM
TJ SD
Feb 16, 2015 11:43 AM
hypophthalmus
Aug 21, 2012 12:45 AM
NoReason
Jul 2, 2010 10:19 PM
ssharber
Sep 19, 2009 09:30 PM
