my intercooler install pt.1
Old Apr 19, 2010 | 06:11 PM
rideracelivemx7's Avatar
rideracelivemx7
figured id share a few pics with you guys of my last 10 hours. yes 10 hours unfortunatly lol. we ended up punching a nice whole in my radiator with the long blade on the sawzall while opening up the cold side of the intercooler threw the rad core support. i was suposed to get more pictures while putting it back together but i was excited taht everything went so smooth that i forgot too! lol the intercooler boots and clamps will be here thursday as well as my long awaited injector orings to do my 2s all this weekend!! woot.
a busted radiators best friend lol, shaun trying to fix that
the way i mounted mine, i didnt like how thin the core support was, and the frame rails were perfect to mount too.
finally! half way done! haha cant wait to start the intercooler pipes. ill start mocking them up later this week.
not sure if youcan spot it, but the first picture of it naked, the driverside frame rail is bent something feirce pointing in! nothing a porterpower cant solve(thanks rich),
all in all, so far i recomment this to anyone, its simple, straight forward and actually alot of fun to do. not looking forward to making my own spider pipe thoe.
Old Apr 19, 2010 | 07:36 PM
427 fordman's Avatar
427 fordman
Looks good. I had mine mounted on the frame to start with and talked myself into thinking that if something flexed b/w the body and frame, ie rubber mounts, the plastic mounts on the ic could break. I changed mine so its all hanging off of the front support. Don't plan on no 4 wheelin to make it flex like that but I get paranoid on some of those things.
Old Apr 19, 2010 | 07:40 PM
rideracelivemx7
well my mounts arent fully 100% tight into the intercooler, about a half inch out so it can flex a tid bit but i dont 4 wheel anyhow, just a road queen over here but well see when it gets buttoned up for good this week.
Old Apr 19, 2010 | 08:27 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Congrats with your work in progress. I have read a lot of posts about the IC install, and nobody mention any mod of the upper supports of the AC condenser, only in the supports on the bottom, did you modified them or not, and why not? why only those in the bottom? . My logic tells me that the modification is to get more space for the IC core, but why only down, is the condenser inclined in some way?
And I saw in your pics that the upper supports of the IC are directly fixed to the core, its that right? did you put any grummets or any alike rubber there?
How did you make the hole in the radiator and how is the name of that paste you put in the pic, that I suppose is to fix it, isnt it? Im asking because Im planning to install my IC and dont want to screw anything
Old Apr 19, 2010 | 09:13 PM
FARM69's Avatar
FARM69
Instead of using a saw-zall to cut the opens, I recommend using a plasma torch to cut the metal out. It's a lot safer and you don't have to worry about the radiator. The metal is thin and will only take a couple seconds to cut.
Setup looks good man.
Old Apr 19, 2010 | 10:49 PM
rideracelivemx7
Rog the sawzal popped out by accident an he was a little too loose on the grip, that's just my crap luck, as for the ac condenser the top mounts are already mounted to the condensor is an inch away from the too of the radiator. You only cut and bend the bottom because it is flaired out a good couple inches and you need all the room you can. If you take your time it comes out nice, almost like it was mention to be an intercooler in there lol as for theflue I used that was jb weld to seal he outside of the radiator. Works like a charm and rated for like 50,000 psi I think? I've sealed up my old 460 block with it, awaome stuff just take your time applying it and use heat lamps. As for the rubber grommets I didn't have any in the garage, I wish I knew I needed them before hand but I picked up the if 10 mins before I started. If you look at the ic installed pic where my bolts are drilled threw, that u shape at the top is for a rubber grommet. I just lightley bolted the. So it can twist with the chassis
I would have used a plasma torch I I had one, sawzal is all I had to readily use at the Moment but I was pretty happy how it came out
Old Apr 19, 2010 | 11:05 PM
strokin'_tatsch's Avatar
strokin'_tatsch
here are some pics for you. Thanks to Cody(Rubberduck) for the pics of these brackets!!! i can't find the pics i took of mine right now, but i did them the same way as this shows.
look at this pic buddy. it's the lower A/C bracket. all you gotta do is beat it down flat right there where the paint is chipped off... it is because it sticks out too far for the IC and you need all the room you can get for these things to push the ends as far to the engine compartment as possible..
Also, Steve... did you cut the hood latch support(the part that runs down to the bottom of the core support) to get the IC pushed in that much closer???? i know i had to cut mine to get it in closer, but i can't tell if you did or not.
This is the driver side bracket. it used to be in an L shape, but you can cut it and clock it over to mount like this.
Old Apr 20, 2010 | 05:53 AM
427 fordman
FYI I didn't mess with my ac mounts at all, didn't know about it at the time. Mine fits, it's tight of course, but it fits. I have a trucool sandwiched b/w the ic and ac too. 1/4" b/w the coolers. Maybe if I would have known about the ac condensor brackets I wouldn't have to shim my bumper out a half inch. Oh well, it works and fits.
I don't know if you need to worry about those mounts on the frame or not. Like I said, I just get paranoid thinking of things that can go wrong and I just wanted that out of my mind so I changed it.
Old Apr 20, 2010 | 06:35 AM
Fullcrew7.3's Avatar
Fullcrew7.3
Looking good rider.
Old Apr 20, 2010 | 09:02 AM
rideracelivemx7
thanks man, too bad my quick fix started leaking today, new raidiator anyone?
Old Apr 20, 2010 | 10:19 AM
cowmilker08's Avatar
cowmilker08
My aftermarket transmission cooler sits on the front of the A/C condenser, will that be a problem when I do my IC?
Old Apr 20, 2010 | 12:07 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Ok, thank you, but Im not Rog . Also, I would like to have a plasma torch to do the work, but I dont.
Sorry to hear about your radiator leak, maybe the weld needed more time to cure? IDK.
Ok, thank to you too. My doubt was about the upper supports of the AC condenser, but I know that nobody modifies them.
Old Apr 20, 2010 | 12:08 PM
rideracelivemx7
depending on how big your cooler is, theres probably 2 inches in between the cooler and the condesor, you may be able to sandwhich it in there but hte thread i got on the 4doorbronco site he fabbed up a quick bracket for his and shoved it infront of the IC. no big dealaslong as you have a good secotion of angle iron. tahts alli used, awsome stuff if you have a good grinder and a few hours to have fun and drink a few beers
Old Apr 20, 2010 | 12:15 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
Look at this diagram and you will see that the position of the Tranny cooler changes its % of efficiency, so you decide. Im going to install it in front of the IC, as most of here do, and I think the reason is the efficiency. I hope this helps in your answer
Old Apr 20, 2010 | 12:26 PM
rideracelivemx7
didnt see the end of your post there travis lol nope! i just put it int he vice and bent it in just a bit, bolted it back in then gave it a good boot and it worked like a charm! nice snug fit about 3/4" of room id say, no rubbing will accure. although i went ona drive today and on the way to school with the windows down i heard a slight creak whe goign around a good bumpy hill. so ill probly head down and grab some rubber gromments and drill another hole on the very top mounts to be assure myself.
