Clutch Pedal/Switch Issue?
Old Apr 18, 2010 | 10:58 PM
SMS888's Avatar
SMS888
I've got a '96 F350 7.5l 4x4 Standard. Ever since I bought the truck, it has become increasingly difficult to start. I replaced the clutch neutral safety switch but I still have to stomp on the pedal to get her to fire up. This switch isn't like the old two wire switches so I don't know which wires to cross. Is there a solution or does anyone know which wires I can cross to make this go away? Getting almost sick of driving this truck cuz I can barely start her. Thanks
Steve
Old Apr 26, 2010 | 01:06 AM
powercoinc's Avatar
powercoinc
Clutch Pedal/Switch Issue ?
Sounds like the Nylon bushing for the Clutch Master Cylinder Push Rod is worn. Check that, as I have to replace mine about every 50,000 miles. The metal lever that actually pushes the rod may also need replaced. Good luck.
Old Apr 26, 2010 | 03:00 AM
RedXL's Avatar
RedXL
I had the same problem on my 94 F150 last year and found a few helpful posts using the search to figure out which wires to jump. It turned out my problem was just a little corrosion on the plug to the crappy plastic clutch pedal switch, but it sounds like maybe your switch is going. If I can find the post again I'll link it to ya.
Old Apr 26, 2010 | 03:31 AM
RedXL's Avatar
RedXL
Maybe this will help.
https://www.ford-trucks.com/forums/6...ty-switch.html
Also check out the link in the second post.
wildmand
Aug 22, 2012 05:19 PM
keith w
43
Sep 8, 2009 11:09 AM
BIIhdridr
Bronco II
Nov 18, 2006 01:49 PM
KSever
Mar 4, 2005 10:12 PM
Ogrebonz
Feb 24, 2005 12:53 AM
