Question about deleting EBPV
Old Apr 18, 2010 | 01:45 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Hey guys quick question. If I delete the EBPV rod in the pedestal will it cause a check engine light?
Thanks
Old Apr 18, 2010 | 01:47 PM
Izzy351's Avatar
Izzy351
No. Soft code only.
Old Apr 18, 2010 | 02:01 PM
tdpower's Avatar
tdpower
You can use a 470 ohm 1 watt resistor across the solenoid plug to get rid of the code. You can also get a code eliminator plug that does the same as the resistor. Not sure if you have to do the smog stuff you might need to do this.
Old Apr 18, 2010 | 03:48 PM
weekendwarriorfsw32
Master of Strokes
Also where do you guys wire the exhaust valve to so it does not close?
Old Apr 18, 2010 | 04:49 PM
weekendwarriorfsw32
Master of Strokes
Never mind we just tacked it closed.
Old Apr 18, 2010 | 04:53 PM
rat49f6's Avatar
rat49f6
when we did chris brownie's we deleted it out of the housing
you can just pop off the rivets and remove the flapper from the rod
Old Apr 18, 2010 | 10:16 PM
ztodd377's Avatar
ztodd377
Can someone show a pic of exactly where the resistor goes? I'm deleting mine since I'm putting the van turbo on but want to put the resistor in there. Also, is that the same size resistor to use for the AIH delete?
Old Apr 19, 2010 | 02:39 PM
aklim's Avatar
aklim
On Cali trucks and Excursions, it might. I got a code fooler from SP Diesel.
Old Apr 19, 2010 | 02:40 PM
Izzy351's Avatar
Izzy351
When you unplug the solenoid, it goes in the plug attached to the wiring. And yes, it's the same resistor (470 ohm, 1W).
Old Apr 19, 2010 | 11:25 PM
ztodd377's Avatar
ztodd377
Do I just wire one wire to the other or put the resistor in line on one of the wires. Sorry for the stupid questions.
Old Apr 19, 2010 | 11:30 PM
mueckster's Avatar
mueckster
Bend the resistor into a "U" and stick the wires into the plug. Double over the ends of the wires of the resistor and it will fit snug on the sockets of the terminals.
Old Apr 20, 2010 | 02:23 AM
UNTAMND's Avatar
UNTAMND
Where does the resistor go for the IAH.
I haven't had an iah for a year now and never had a light come on. Granted only a few night was cold enough to need it. I'd like to know so I can do it and not be bothered by a code later on.
Old Apr 20, 2010 | 04:04 AM
amthatiam's Avatar
amthatiam
I used ITP's big bore outlet to eliminate the butterfly in the exhaust and when I replaced my turbo pedestal with the EBPV delete version, I removed the sensor and plugged it in and leave it in the valley, eventually will probably get the resistor.
Dan
Old Apr 20, 2010 | 07:08 AM
mueckster's Avatar
mueckster
There are a few more pics in my gallery.
Old Apr 20, 2010 | 09:31 PM
ztodd377's Avatar
ztodd377
What's the sensor that plugs into the bottom of the spider right between the map line outlet and where the red line normally plugs into?
