Transfer case shifter
Old Apr 18, 2010 | 09:42 AM
bmac6446's Avatar
bmac6446
I broke the transfer case shifter off of my '94 F250 a couple years ago while trying to pull it out of 4x4. The whole thing seized up and I ended up snapping the whole assembly right off the mount bracket. Where can I find a replacement shifter assembly and most importantly, the mount bracket?
Old Apr 21, 2010 | 08:54 PM
4x4truckdriver's Avatar
4x4truckdriver
shifter
You can try Green Sales in Cincinnati, 513-731-3304, they have stock on a lot of Ford parts and usually cheap. Mine broke two weeks ago and I had it tig welded back together. But when the shop welded it the plunger seized up and ruined the unit. I will have to find a new one as well. Greens does not have my unit-maybe yours...
Mine broke because the bolt on top was seized up so you could also try JB Weld, but free up the top mounting bolt so the unit can rotate first. Good Luck
Old Apr 22, 2010 | 09:00 AM
jas88's Avatar
jas88
You can find them on eBay but they are spendy.
Old Apr 22, 2010 | 09:24 AM
andym's Avatar
andym
Try a junkyard, too. A pick-n-pull should be pretty reasonable for something like that.
djmichael24951
16
Apr 6, 2014 08:11 AM
RXRR
Jan 23, 2006 07:24 AM
fomoco3904
Mar 10, 2005 11:32 PM
Tipher
Mar 23, 2002 10:56 PM
