Back window installation
Old Apr 17, 2010 | 07:08 PM
Joco's Avatar
Joco
I have a 72 F100 short bed that I will be taking the shell off (anyone want it) and replacing the back window. I have the window and rubber seal (both original I think). What is the process for installing the window? I have tried searching the sight but didn't really find anything.
Thanks for any info.
Joco
Old Apr 17, 2010 | 07:51 PM
Ford_Six's Avatar
Ford_Six
Put the gasket on the window, then stick a corner of it in the opening, use a screwdriver to push the inner lip of the gasket in place, and work your way around. It gets a bit tricky towards the end, but not hard at all.
Old Apr 17, 2010 | 08:06 PM
gangstakr's Avatar
gangstakr
There is a section called "search this forum" located on front page. I typed in "installing back glass" and here is what popped up:
Seems like everybody has an opinion on this and it'll be cool to hear 'em.
My way of thinking is to let gravity help you out instead of fighting it.
So, I start just above a bottom corner and go down and across the bottom.
I was told to start with a new gasket since they are easier to work with, they
are relatively cheap. You don't know how long the old one is going to last see?
I know you are doing that one already, just wanted to mention it.
Soapy water, thick and slick like used for <NOBR style="FONT-FAMILY: verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; COLOR: darkgreen; FONT-SIZE: 100%; FONT-WEIGHT: normal" id=itxt_nobr_8_0>tire</NOBR> patching/replacing. I've used
WD-40 before too, but it's hard on the rubber and will make it crack sooner
than it would have otherwise.
As far as string goes, just about anything will do if it isn't too weak and thin.
Too thin makes it want to cut the rubber. BTDT :/
Most of the "pros" I've watched used 3/16" "braided" nylon rope, not the
"3 strand".
Solid Braid Nylon Rope * U.S. Rope and Cable
If this is your first... you picked the right one to learn on, IMO!
It's the easiest I can ever remember doing... the rear glass on my '75.
A lot of questions can be answered using "Search this forum"
I copied this from the thread I hope the original poster don't mind.
Joco
Jun 13, 2014 02:04 PM
Joco
43
Feb 21, 2014 05:14 PM
Joco4x4
2004 - 2008 F150
Feb 27, 2013 08:49 PM
Joco
19
Dec 8, 2011 05:20 PM
Joco
Mar 11, 2011 11:45 PM
