Steering box adjustment.
Old Apr 16, 2010 | 11:42 PM
79FordBlake's Avatar
79FordBlake
I am needing to adjust the slop out of the steering box on my 73 F100. I checked the coupling and steering linkages, they are all in good shape. Manual steering.
By reading the manual I need to make sure the box is in its center position of travel then adjust the steering shaft adjuster screw till there is little play?
I don't have a torque wrench small enough to measure preload. It steers fairly easy now. I guess I will have to get a torque wrench if its hard to turn after the adjustment to adjust preload.
Anything I might be missing? Seems pretty easy to adjust.
Old Apr 16, 2010 | 11:46 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
It's easy to adjust, just do small increments at a time, like 1/8th a turn. It's pretty easy to adjust it too much and lock up the box, either in the driveway or worse while going down the road when youn least expect it.
Josh
Old Apr 17, 2010 | 12:13 AM
79FordBlake
I guess its best to have the front end up on jack stands. Adjust the screw in a tad then turn the wheel lock to lock to make sure its ok each time?
F250SuperCab
18
Oct 1, 2020 08:42 AM
Adigo
Jan 16, 2016 02:17 PM
Daniel Black
Aug 26, 2015 12:06 PM
daniel47
Nov 10, 2009 11:36 PM
RedDawg
Aug 24, 2005 09:48 PM
