please help
Old Apr 16, 2010 | 08:47 PM
Ozone-etr1's Avatar
Ozone-etr1
please help
this morning i get in to the truck and for the first time it started ran for a minute then died.Did this three times till it finally ran solid after starting.
THEN 2 min later the truck statred to buck and idel high like at 2300 rpm
then back to idle then to 1500rpm. when it would spike in RPM it iluminated the check bat lite on the dash did this for about 25 minutes bucking and jerking to the point it died and i had to restart it and it started on time and had a little miss but not much.no smoke the oil is up to par and i have just had both bats checked...i useually get my own problems worked out but this is STRANGE...please help with the question and answer format,
Or give me a call 479-719-7168(not all at once tho)
2003 6.0l ford f250
joseph
Mods:
oil bypass modified intake
SCT
R&R fule system 4" t/b exhaust streight
ele gadges
<!-- / message --><!-- sig -->
Old Apr 16, 2010 | 09:10 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Sounds like it could be a bad ICP sensor. See if your SCT will pull a trouble code.
Here's a couple of threads out of the 6.0 tech folder sticky at the top of the page that will help:
https://www.ford-trucks.com/forums/8...with-6-0l.html
https://www.ford-trucks.com/forums/8...ml#post7693493
By the way...welcome to FTE
Old Apr 16, 2010 | 09:13 PM
Ozone-etr1's Avatar
Ozone-etr1
i'm a heave active member of another site but would the ICP cause the bat lite to come on? and flicker
Old Apr 16, 2010 | 09:16 PM
Zmann's Avatar
Zmann
the batt light might be from the failed starts and batt draining glow plug cycles
Old Apr 16, 2010 | 09:20 PM
Ozone-etr1's Avatar
Ozone-etr1
granted would it indicate a bad bat if after 4 hrs running that the bats only (KOEO) 12.3v and for some reason 896CCA but the bat is rated for 750CCA
Old Apr 16, 2010 | 09:29 PM
Zmann's Avatar
Zmann
no the batts would need to be way lower ,, you may have the dreaded bad battery cables ? that is a guess however
