this morning i get in to the truck and for the first time it started ran for a minute then died.Did this three times till it finally ran solid after starting.
THEN 2 min later the truck statred to buck and idel high like at 2300 rpm
then back to idle then to 1500rpm. when it would spike in RPM it iluminated the check bat lite on the dash did this for about 25 minutes bucking and jerking to the point it died and i had to restart it and it started on time and had a little miss but not much.no smoke the oil is up to par and i have just had both bats checked...i useually get my own problems worked out but this is STRANGE...please help with the question and answer format,
Or give me a call 479-719-7168(not all at once tho)
2003 6.0l ford f250
joseph
Mods:
oil bypass modified intake
SCT
R&R fule system 4" t/b exhaust streight
ele gadges
<!-- / message --><!-- sig -->
