Question about a 360 piston/rod combo
Old Apr 15, 2010 | 08:59 PM
zerfetzen's Avatar
zerfetzen
I was just toying around with options for my 360, and was wondering:
Could I keep the same crank, use a 390 piston (such as Federal Mogul's cheap P381NP with 1.66 compression height) and put the 6.7" stroker rod together?
According to my math, I'd get about 9.45:1 static compression (assuming 72cc heads, gasket bore and thickness, etc.).
Are there any piston/rod combos that work here? I don't want to drop the crank if I don't have to. Thanks.
Old Apr 15, 2010 | 09:58 PM
HillbillyDeluxe81's Avatar
HillbillyDeluxe81
Don't the 6.7 stroker rods have a 2.200 big end?? Meaning you must machine your crank to BBC size??
Old Apr 15, 2010 | 11:52 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
You can find 390 cranks all day long at the wreckers for under $50, grab some rods and get some new pistons and you're done.
Josh
Old Apr 15, 2010 | 11:57 PM
HillbillyDeluxe81
.....I'm not sure why he does not want to remove the crankshaft. Trying to replace pistons with the block still in the truck??
Old Apr 16, 2010 | 12:19 AM
Bullitt390's Avatar
Bullitt390
Hmmm... must be. If the engine were on a stand you would LIFT the crank, not drop it.
I would reckon the easiest thing to do is to find a running 390 engine and swap motors rather than mess with trying to monkey new pistons and half-assed rods on a crappy 360 crank.
Josh
Old Apr 16, 2010 | 05:58 AM
zerfetzen's Avatar
zerfetzen
That'll about do it, it needs a 390 crank then. I was just hoping. I'm planning on tearing it all apart, but leaving the block in the truck.
I was just wondering if I can leave it technically a 360 still by leaving the crank in place, unbolting the rods, driving out the old piston/rings/rods, and putting new ones in place that get better compression.
Guess not, and thanks.
Old Apr 16, 2010 | 09:31 AM
starmilt's Avatar
starmilt
Same crank= same stroke, same bore, you still have a 360.
Old Apr 16, 2010 | 07:36 PM
Bullitt390's Avatar
Bullitt390
If all you want is higher compression then you have the option of having the heads milled and installing thinner head gaskets.
Josh
Old Apr 17, 2010 | 07:02 AM
zerfetzen's Avatar
zerfetzen
Thanks Bullitt, I'll look into that.
