will 35's fit
Old Apr 15, 2010 | 03:23 PM
pcbkevin's Avatar
pcbkevin
will 35's fit
2001 f250 4x4 crew cab short bed 7.3 psd with 2" inch lift in front. will 35's fit?
Old Apr 15, 2010 | 04:17 PM
PlatinumPSD's Avatar
PlatinumPSD
will need to cut some stuff like your bumper and some tire brands are diffrent but they fit on a friends truck 35/12.5/16 BFG all terrains dont know about mud terrains.
Old Apr 15, 2010 | 04:33 PM
lilrebel64095's Avatar
lilrebel64095
should fit. might have to make some modifications like PlatinumPSD said above. but wont have much flexing room in your wheel well. and will have to watch for it to rub when you turn your tires all the way in both directions, some will rub some wont mainly depends on the width of the tire and if you have deep dish wheels or wheel spacers.
Old Apr 15, 2010 | 06:27 PM
crum71's Avatar
crum71
1/8 mile Oval Track
Depends on backspacing of the wheels and tread of the tires. I had just the shackles on mine,and the driver side eat the new inner fender out like the last one. Plus eat the edge off the bumper valance. You can take the bumper off and space it out with washers just a little or cut the lower corner off. As for the inner fender,drill 2 small holes in it,using zip ties, pull it back as far as it will go. That should make them work.
Old Apr 15, 2010 | 07:31 PM
PlatinumPete's Avatar
PlatinumPete
There's a guy on here, F350kidd (I think is his user name), who I think has an '02 supercab 4x4 shortbed, and he has 35's on it without even his leveling kit on yet. They rub but not terribly and he daily drives it. As mentioned above, you might have to do a little modification but other then that you should be all set.
Old Apr 15, 2010 | 11:09 PM
Rubidon's Avatar
Rubidon
I have a completely stock '99 7.3 4door supercab running 315's mud tires and the only problem I have is if I turn to sharp. I think it is like they said about the rims back spacing!
Old Apr 16, 2010 | 07:17 AM
03_PSD's Avatar
03_PSD
I'm going to try that zip tie idea out, these 325/65/18's slightly rub my inner fender.
Old Apr 16, 2010 | 08:52 AM
DieselBeast01's Avatar
DieselBeast01
I have 35/12.50/r16 nitto mud grapplers on mine with a little over 3 inches of lift in the front and they don't touch anything.
Old Apr 19, 2010 | 12:53 AM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
Nitto mud grappler 315-75-16's on mine with very little rub. Going to do the zip tie thing. Oh and 4" lift.
BlueOvalDismantlers
18
Oct 22, 2024 10:39 AM
NASTseventhree
Mar 11, 2011 08:51 PM
gmbtowing
2004 - 2008 F150
Apr 26, 2010 08:41 PM
Scoop531
Apr 9, 2007 02:13 PM
dscofever
Feb 22, 2006 10:14 AM
