Sponsored by: Real Truck
Brake controller mounting
Old Jan 28, 2003 | 04:21 PM
Fishin-Technician's Avatar
Fishin-Technician
Just wondering where others have been mounting their brake controllers on the later model superduties?
I mounted mine real quick during the summer months, just right of the gas pedal and left of the center of the transmission hump..........not a good spot, it blocks the heater air flow to drivers feet,,,,,,,,,NOT good in Albany, NY this time of year.
Old Jan 28, 2003 | 04:36 PM
scratcherky's Avatar
scratcherky
I have a 2000 SD and I mounted mine in the little storage box just to the right of the steering column.
Old Jan 28, 2003 | 04:57 PM
nafzimo's Avatar
nafzimo
Here's mine! 3M Automotive Double Sided Tape (Walmart) made it through the summer and so far through the winter.
Old Jan 28, 2003 | 05:47 PM
pjrf350's Avatar
pjrf350
I mounted mine in the same place as nafzimo, but used 3m clear hook and loop fastener. So can be removed easly.
hope this helps
Old Jan 28, 2003 | 08:32 PM
nafzimo's Avatar
nafzimo
I tried Velcro but the adhesive did not stick to the dash. It fell off after two hot humid days last summer. Plus, the Prodigy comes with the "pocket mount" so I can unplug it, remove it from the dash and lock it in the glove box.
Matt
Old Jan 29, 2003 | 12:05 AM
Aaron S's Avatar
Aaron S
Mine is mounted in the cubby hole above where nafzimo put his.
Aaron.
Old Jan 29, 2003 | 06:21 AM
GAV10's Avatar
GAV10
Mine is in cubby hole also...
GAV10 Mark
Old Jan 29, 2003 | 08:35 AM
79CEEJAY's Avatar
79CEEJAY
Mine is in the litle cubby also. Used velcro to hold it firm and just drilled a 3/8" hole to feed the wires through. Looks neat and is in a good location. It can also be mounted in the little indention just below also. Either location is good though.
Old Jan 29, 2003 | 09:18 AM
Wheels's Avatar
Wheels
I put mine in the same location as Nafzimo, I used screws.
Old Jan 29, 2003 | 09:19 AM
BozemanBeast's Avatar
BozemanBeast
Thsi is a great question, cuz I"m putting mine in this afternoon. That spot won't work on mine. I have the stick shift, it will hit.
I'm thinking just right of the steering column, on hte plastic and above your right foot.
other ideas?
Old Jan 29, 2003 | 10:45 AM
Dwight Crumpacker's Avatar
Dwight Crumpacker
Mounted mine under steering wheel where the cover is for the turn signal. Right handy and the electrical conections are handy, and it is there so you use it with out any distraction.
Old Jan 29, 2003 | 11:35 AM
nafzimo's Avatar
nafzimo
Originally posted by BozemanBeast
... That spot won't work on mine. I have the stick shift, it will hit... other ideas?
Yea, mount it where I did and don't use first and third.
Matt
Old Jan 29, 2003 | 12:16 PM
bddo's Avatar
bddo
Mine is in the same place as NAFZIMO's, but when I get my new Prodigy, I am going to mount it in the little tray space above the current location like Aaron did.
Old Jan 29, 2003 | 12:31 PM
Dwight Crumpacker
Matt
Old Jan 29, 2003 | 12:34 PM
Dwight Crumpacker
Matt
I have a 2002 F350 auto, even a stickshift shouldnt bother the controller, its about 1 inch infront of the steering wheel underneath it. What kind of shifter do you have . Sound like a 4 ft stick from a hot rod!!!!!!:
