Drove the 1984 F250 2WD 5.0L the other day and it would shift out of first but never engage second gear. It was about a mile to return home which I did (slowly). The transmission shop said that there is valve in the carb that sends a vacuum signal to the transmission to shift. They often degrade. Easy fix but they told me that driving in this condition could reck the tranny. They replaced the part and indeed they said that 4th gear is "burn" and the tranmission has to be rebuild. Should cost less than $2,000 OUCH. I would like to know if this is a common problem and if the cost to repair seems resonable. I love that truck and will pay the expense just want to make sure I'm not being taken for a ride. Thanks friends.
Well, first off, the 4 speed auto doesn't have the modulator valve.
There were 2 auto trans available in 84. A 3 speed (C6) and a 4 speed (AOD). Neither should cost anywhere near $2000 to rebuild.
I'd say get a second opinion.
I'm not real familiar with the AOD, but I think they use either a rod or cable along with internal RPM sensors to decide what gear to select and when to do it.
Thanks Rogue, It is an AOD. If there is no "modulator" where does in shift signal come from?
The AOD does NOT use a vacuum signal to shift the transmission. The transmission line pressure that shifts the gears is controlled by a throttle valve "TV" rod (some models used a cable) that runs directly from the transmission to the carburetor throttle lever. This is a *very* critical adjustment. If this rod or cable is not adjusted correctly, or comes off, the AOD transmission will burn up - FAST.
On carbureted models, there is a rubber bushing that fits the TV rod to the carburetor throttle lever. If this bushing deteriorated and the TV rod came loose or came off, it could have very well burned up the clutches in the transmission if driven that way for very long.
I had my AOD rebuilt two years ago for about $1000.
Where do you get this rubber bushing? I found a concaved washer that seemed to fit into the linkage but reading how critical it is has me worried now.
Sorry to steal your thread.
The aod is a simple transmission from what I have been told, around 1200 parts and labor.
As an example of how cheaply a trans can be rebuilt, I had my C6 rebuilt a couple years back. $200 for parts, and $250 labor for R&R + rebuild, with 5yr/75K warrenty.
An AOD would be a bit higher than a C6, but $2000 is excessive. I'd bet that kind of money would get you a new trans from ford......
not to sure about AOD trannys. But i got quotes on a c6 of course in washington state. and that was only 600 to 800 to rebuild and that with a new casing. i would aggree with the above people that 2000 is a little high. I would goto yellowpages.com and search transmissions and call a few places
My dad had his C6 rebuilt for $600.$2000 is way too high IMO.I wonder if the owner is familiar with the AOD and charging that to try and keep from working on it?
Post #11 reminded me,my dad's truck was originally an AOD truck,but a previous owner swapped it out to the C6.The truck only had 80,000 on it when my dad got it,and my dad said the truck was well cared for by an older man,so the AOD musta been one of those that was destined to fail early.I can't trash talk the AOD because i've seen some last pat 100,000,but you still have to know how to service them to achieve that in most cases.
I have an AOD in my F250 & got prices a couple of years ago to rebuild it & also on rebuilding a C6, as a replacement option.
At the time it would have cost me (in New Zealand $) $2000 to get a C6 core, & have it rebuilt & installed.
To remove, rebuild & reinstall my own AOD trans would have been $2500, by the same company.
The AOD isn't very durable without upgrades, & the price you were given probably was taking this into account.
I decided to go to a manual trans, just because I don't particularly like automatics.
But as Rogue Wulff said, the AOD doesn't have a modulator valve, the C6 does.
I honestly wouldn't waste my time with an AOD in a truck, a 4r70w can be had if you want to keep Overdrive with all the upgrades already in place, or you can go C6 easily enough as well.
sorry to sound like a noob here but what is a 4r70w? i have a c6 in my f350 and man does she like gas overdrive sounds great, and everything iv heard tells me not to waste my time with an aod.
ok just read up on it so next question is would it bolt up to a 460?
