I have a 2008 F-250~
This problem has been making me CRAZY Temp gauge registers HOT (even though it is not overheating) icon flag comes on and it says "Reduce Engine Power" It has been in service numerous times they can't seem to figure it out?? (just got it back yesterday) It did it again on my way home from work...Has anyone heard of this problem??
Had this same EXACT problem when I first bought my truck. The temp gauge would peg only minutes after starting down the road. Threw codes and the overheat message. I knew the engine wasnt hot cause it had only been running for 3-4 minutes. After it pegged, it would eventually go back down. They traced it, FINALLY, to a bad sensor, one of 2 which measures temp coolant. Hope this helps.
I need to know what sensors you had to replace because my truck just did this to a tee. It is not over hot but gauge was reading max temp. It is running fine no changes. I need to fix it asap so any help would be appreciated.
