Help daily driver
Old Apr 14, 2010 | 07:43 PM
fordstaf's Avatar
fordstaf
Question Help daily driver
Did this troubleshooting: replacing the CPS; there is no water in fuel; HPOP has good level; Batteries are good, Glow plugs good; no smoke when cranking; ether test gave no smoke but closer start up; fuses and relays good; the fuel has good pressure to injector pump but not to injectors.. any ideas??
Old Apr 14, 2010 | 08:05 PM
fordstaf's Avatar
fordstaf
1996 F-350 7.3 wont start...
any ideas ???
Old Apr 14, 2010 | 08:08 PM
Hussler's Avatar
Hussler
Does the WTS "wait to start" light come on when turning the key?
Old Apr 14, 2010 | 08:11 PM
fordstaf's Avatar
fordstaf
yes, the lights cycle
Old Apr 14, 2010 | 08:12 PM
fordstaf's Avatar
fordstaf
Old Apr 14, 2010 | 08:19 PM
FARM69's Avatar
FARM69
Check fuse #22 in the black fuse box in the engine compartment.
Old Apr 14, 2010 | 08:21 PM
Hussler's Avatar
Hussler
Need more information on what happened?
Such as .. I was driving down the road and just stopped or I've had the truck sitting in the driveway for the past two years and now it won't start. Hugh difference.
Old Apr 14, 2010 | 08:23 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
Let us know more about your truck. Any mod, chip, tuner, etc?
How old is your oil, and is the level right?
The starter is working fine?
BTW welcome to the forum.
Old Apr 14, 2010 | 08:33 PM
fordstaf's Avatar
fordstaf
I am not sure how to work the computer thing so I am sorry it takes so long to get back to you all... and thank you for your imput...
We drove the pickup saturday was running as good as a top. We went to get flowers on sunday afternoon and the pickup wouldnt start, it turns over but not starting. strange thing is there was no sputter, pop unusual sounds or anything.
Old Apr 14, 2010 | 08:34 PM
fordstaf's Avatar
fordstaf
oil level is great it has about 900 miles since last oil change
Old Apr 14, 2010 | 08:35 PM
fordstaf's Avatar
fordstaf
Thumbs up
thank you
cowmilker08's Avatar
cowmilker08
Check the connections going into the Valve Covers.
There is no Injection pump on Powerstrokes.
They have a HEUI (Hydraulic Electric Unit Injection) system.
Engine oil pushes a piston that forces the fuel into the cylinder at 2600 psi.
The fuel pump under the turbo pumps up fuel from the tank into the bowl then back to the other side of the pump then to the injectors at around 60 psi at idle.
If you checked the fuel pressure via the schrader valve on the Fuel Pressure Regulator (FPR), it only needs to be 25 psi for the truck to start.
Old Apr 14, 2010 | 08:37 PM
fordstaf's Avatar
fordstaf
fuse 22 is good, still changed it though.
everything is stock except the train horns ;-)
Old Apr 14, 2010 | 08:39 PM
cowmilker08
Nice!
Make sure the plug on the passenger side of the fuel bowl is still plugged in. The valve that controls the oil pressure to the injectors is controled electronically through that plug.
fordstaf's Avatar
fordstaf
Question
I am the wife.. forgive me for my ignorance. is that the valve that you use the tire gauge on?
